Question about Electrolux Refrigerators
Camper fridge ignites and runs on gas then fails
Fridge is fitted in a camper van and works ok on 12Vdc and 230Vac but on gas it ignites and runs (I can hear the burner and feel the heat via the exhaust) for approx 30/40 minutes then it fails and the igniter switch clicks away but doesn't ignite. I think a reset of some sort is involved for if left switched off for a while it will restart and runs ok for the 30/40m period.
Many thanks your advice Derek
  • 400 Answers
I beleive the thermocouple is faulty, this allows gas to flow once the flame is lit, but will also close the valve if faulty. Rateme
Posted on Mar 11, 2009
Can a dometic RF 60 absorbsion fridge be used in a camper van if gas is not connected?
google search shows that it is a 3 way fridge --12v/ mains /gas
it will operate off the battery, mains plug in ,or from a gas bottle
so --yes it will operate without a gas connection
it is not suitable for a built in application but is stand alone unit
Jan 15, 2017 | Dometic Refrigerators
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The fridge will not turn on. Should I be turning on the 100 switch, even if the camper is plugged in, and the lights are working?
Do you mean the 110VAC switch? Unless you are running the fridge on propane, it will need something to power it and if the camper is attached to power the fridge can be run on AC.
Sep 01, 2009 | Dometic WA3210 Compact Refrigerator
Camper fridge
if it is a 3 way fridge pull it out and turn it upside down and leave for an hour or so and then turn back for an hour or so and continue this for half a dozen times the gas inside the pipes have seperated and require mixing up particually if it is fairly old or has been sitting for a long period as u discribed
Jul 28, 2009 | Danby DCR34 Compact Refrigerator
Fridge in VW camper van
CHECK appliancesfactoryparts.com
Jul 26, 2009 | Refrigerators
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
Power in my T25 1985
Just a thought, but it might have a Leisure battery fitted and all the elec's could be run from there, check to see if the second battery is fitted and/or connected
Aug 17, 2008 | 1986 Volkswagen Wagon Camper
Refrigerators Logo
275 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
