Question about RIM BlackBerry Curve 8520 Smartphone
Blackberry camera problem
When I try to open my camera, it displays a message reading "Could not start the camera. Pls close other application and try again."
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Any other program using the camera? (such as custom filters.. etc) if you have anything that is using the camera application then it won't actually close until you close the hosting program; easiest way is to take out the battery WHILE THE PHONE IS ON (important part, that's why I yelled it :) ) and leaving it out for about 10-20 seconds, reinsert and try again
Posted on Apr 18, 2013
SOURCE: my blackberry storm camera quit working. it says
if you hold down the blackberry button....(dots).....a menu will pop up ....those are all the apps the you still have open...go into all of them and make sure you manually close them out....choosing the close selection on the menu....and ur camera should come right back on...the same happened to me......
Posted on Dec 27, 2009
SOURCE: could not start the camera. Close other
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Posted on Jun 30, 2009
kachi_1
  • 677 Answers
SOURCE: whenever i open up my
Hi, when a camera says could not open the camera close other application and try again ,means that either to much application where opened at a tie or the camera is corrupted.
First, scan through phone and see if unnecessary applications where open,If not, that means the camera is faulty and will eeed to be replayed.
Posted on Aug 07, 2010
SOURCE: when i go on my
when i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
Posted on Oct 20, 2010
caroldon
  • 17130 Answers
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Feb 12, 2011
Could not start the camera close other applications and try opening the camera again blackberry
could not start the camera close other applications and try opening the camera again blackberry
Dec 07, 2010 | RIM BlackBerry Pearl Smartphone
When i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
Oct 10, 2010 | RIM BlackBerry Curve 8520 Smartphone
Whenever i open up my camera it says "could not start the camera. close other applications and try opening again."
Aug 07, 2010 | RIM BlackBerry Bold 9700 Smartphone
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
My blackberry storm camera quit working. it says could not start the camera. close other applications and try opening the camera again. i dont have anything else open
Dec 25, 2009 | RIM BlackBerry Storm 9530 Smartphone
Camera ERROR MESSAGE Blackberry Curve (Sprint)
Your OS maybe corrupted so you will need to reinstall the OS, you can do this by connecting the phone to your pc/laptop using the USb cable then open the Blackberry Desktop Manager and click on the apploader then install the applications and install the OS as well as the features for the phone....
Thks
Bajan Guru
Barbados4life
Dec 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Sony Ericsson W350i camera not working
sony ericsson camare problem...when i will start camare ,,display message 0 hold ,,another application running ,,close to start
Jun 27, 2009 | Sony Ericsson W350i Cell Phone
Could not start the camera. Close other applications and try opening the camera again
Feb 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
RIM BlackBerry Curve 8520 Smartphone Logo
277 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
