Question about ASUS Eee PC 1000HA Netbook
The built in webcam says not connected
Its new and i still used it but later on it says not connected
I just bought a dell laptop with a built in webcam and it works great on oovoo and everything but it wont let me record or post videos on my friends facebook walls. All it says is "an error occured....
This may be an issue with the version of Flash that you have installed -- if you have it installed at all.
Got to the Flash about web site to see if you have the latest version of Flash and upgrade/install as needed.
Additionally, when the Flash application request permission to use your webcam, be sure to approve and save your decision.
Dec 27, 2010 | Facebook Social Network
I've got a new HP laptop with built in web cam (youcam). Everytime I go to use though; it's always a couple seconds off. I move and a couple seconds later the video moves. My voice is also off with the...
Are you using it along with other heavy programs? Example running webcam + playing a game or something/facebook games? This uses up the memory and will slow down your webcam.
Are you experancing it only when your webcaming someone? Example, skype webcaming, depending on your internet speed you will see a lag in the video.
Dec 15, 2010 | HP Computers & Internet
No sound. how do I get the audio activated?
You do not give your set-up (laptop or desktop etc)
You do not give your OS (XL or Vista etc)
You do not say what chat program you want to use
This is an example for setting up a laptop (with built in mic) and webcam (with built in mic) and Vista OS to Yahoo Messenger
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
Jun 03, 2010 | HP KQ246AA Deluxe Webcam
There is no sound
Make sure you have your webcam mic set as default - especially if you have a laptop with a built in mic
TEST SPEAKERS
Restart computer
Apr 20, 2010 | Veo Velocity Connect Webcam
Pc webcam ywb-1016, video works, but audio(built-in mic) doesnt
You may have to tell your computer what mic you wish to use ( make it default )
Typical audio set up
Laptop/mic x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Jan 19, 2010 | GE EasyCam Webcam
How do I use & connect the built-in webcam?
hi!
-you need to install the driver for the web cam first
-you can open the program after installation Dell WebCam manager
Oct 23, 2009 | Dell Inspiron 1720 Notebook
Acer webcam
You need to click on [Start] then click on [My Computer] and then [Acer Crystal Eye Webcam] will show up then click on the [Camera]. If this does not work then it could be that the cam driver needs reinstalling or maybe faulty. Take it back to your dealer!
Jan 09, 2009 | Yahoo Messenger
Using new Satallite P200-1EE, webcam is not connected message with Yahoo Messenger
I'm using a Toshiba satellite notebook A200, which I faced the same problem like you saying my built- in webcam cannot operate after I clicked on the drop down list from the windows live messenger to have a webcam conversation. Another program is running the webcam at startup. That program is called Camera Assistant Software which is the conflicting software. Therefore I closed this software and I'm able to use my webcam again in my webcam conversation in windows live messenger. I hope this information will help you.Good Luck!
Dec 22, 2007 | Toshiba Satellite A135-S2276 Notebook
Acer's built in webcam
Did you install the necessary drivers for the webcam. If not, use the CD that came with the laptop to install the drivers and then try to use it with Yahoo, etc..
Mar 07, 2007 | Acer Aspire 3000 Notebook
ASUS Eee PC 1000HA Netbook Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
