Advent power adaptor flashes green
Plug the adaptor in to the plug socket and the light is green , plug into the laptop and it blinks and wont work the laptop.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Does the charge light come on? It could be the connection piece of it, they are made pretty flimsy..
If you know how to safely do this check the voltage on the computer side of the adapter for the proper voltage.. sounds like it's on it's last legs though.
Posted on Apr 18, 2013
Testimonial: "The charger light just flashes and no lights on the laptop"
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Posted on Jul 14, 2008
Pyrhyc
  • 2028 Answers
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
MPetro302
  • 298 Answers
SOURCE: Need to open Advent 7072 case to resolder power jack socket...How?
This is something that should be left to a professional. A local repair shop should be able to handle this task easily. but if you insist you can try here
Posted on Apr 17, 2009
jaipalsidhu
  • 39 Answers
SOURCE: Vostro 1500 Charger Light goes off when plugged into Laptop
Which window is running on ur laptop ?
Posted on May 18, 2009
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Advent Netbook 4489
IT sounds like you need to replace your battery. If your laptop (notebook) is working properly while plugged in with Ac power we know it is not your power supply.
I would visit the manufacturer's website for replacement batteries. One complaint I have read about over and over on these particular systems is that the battery life is very poor.
Sep 17, 2009 | Advent Netbook
Charging issue
It’s either the plug on the AC adaptor (might have a broken wire) or the laptop’s input jack that the adaptor plugs into. The input power jack is soldered onto the motherboard. Could also be a problem with the charging circuit on the motherboard (would need to replace motherboard to fix).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 15, 2009 | Dell Inspiron 9100 Notebook
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop won't turn on
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
