Question about HGST a Western Digital company Hgst Touro Desk 4tb Usb 3.0 Desktop External Hard Drive Black 0s03396
HGST Touro Desk 4TB USB 3.0 problem with bitlocker
Windows 7 Ultimate will not run bitlocker only on this drive
ANY DRIVER FOR TOURO MOBILE MX3 USB 3.0?
go on line for your model and down load the driver or if in windows add the machine and let windows search and down load the driver for you.
Jul 06, 2014 | HGST 1 TB Touro Mobile MX3 USB 3.0...
Hitachi
open the case , take out the drive , attache it to a computer internally ,youll need a cable or borrow you cd's cable, turn drive on in the bios to see drive ,save , boot an let windows load it , now does it come up as a drive letter an can you scan fix it . right clik that letter , properties , scan an fix. now thats assuming the drives have windows compatible sectoring an software that formatted it for your data to hold on it.
if you get an error before you get into windows then the drive has likely died in one of many ways.
Jun 25, 2014 | Hitachi 2TB Touro Desk USB 3.0 External...
Hitachi hgst touro desk 4tb
hello,
one way is to try to recover your data using simple program like hirrens boot cd,if this will wotk then you are done if not you will need to chosse data or hdd.
Jan 21, 2014 | Western Digital Computers & Internet
Needed is an operation manual "how to" for HGST Touro 4TB external hard drive machine just bought. Want to know how to transfer files from computer to external storage?
FIRST the short ANSWER; Open Windows Explorer and drag and drop files/folders to new drive.
LONG ANSWER; Connect drive,during boot up of PC, and ENTER (CMOS) SETUP. See if drive is listed.
IF LISTED resume boot and see if Windows FINDS new Hardware and installs it. If so go to short answer.
If not seen by windows but seen by CMOS the drive must be PARTITIONED and then FORMATTED. OR
IF disk came with install CD run install to assure all needed USB drivers are present for windows to install disk through USB port.
Once USB drivers are installed reboot PC and see if Windows finds new hardware.
IF windows still does not install new HD but CMOS shows drive is present, the drive needs to be partitioned.
To partition new drive type DISKPART at dos prompt or in START RUN OPEN and press enter.
At the DISKPART> ( prompt ) type LIST DISK then press enter.
Example: DISKPART> LIST DISK press enter
FIND the number assigned to the new drive in the list (#), then type SELECT DISK #
Example: DISKPART> SELECT DISK 2 press enter
the info returned in the dos window should be;
Example: Disk 2 is now the selected disk
Type CREATE PARTITION EXTENDED
Example: DISKPART> CREATE PARTITION EXTENDED press enter
Now shutdown the PC then reboot. Windows should now Find hardware and install new disk.
Click START then COMPUTER the new disk should be listed.
Right click on the Drive and select FORMAT use NTFS format.
now you should be able to drag and drop files/folders to your new disk.
Oct 16, 2013 | Computers & Internet
My hitachi touro desk dx3 2tb hard drive use to work fine on my mac then i plugged it in to a windows 8 pc, since then the hard drive will only work on the windows8 and not my macbook, how can i fix t
Thanks for asking your question on Fixya. ;-)
What error messages are you seeing, if any? Does Apple OS recognize it at all? Also, did you format the drive on a windows computer? How about deleting the partition and plug it back into the macbook so the macbook can set it up for you. If you plug it into the windows machine, what messages did you get from that?
Jul 21, 2013 | Hitachi 2TB Touro Desk DX3 USB 3.0...
Hitachi touro usb 3 hardrive will not work in windows 8
I contacted Hitachi support, no solution. They say we should return and exchange the disk with a new model that supports Windows 8.
Very very fustrating.
Jan 23, 2013 | Hitachi Gst Hitachi - Touro Desk Pro USB...
My Hitachi Touro 4TB external hard drive get stuck every time I try to transfer large files. How do I fix that? The format is NTFS and the files are 4g and up.
External hard drives are popular portable storage devices because they allow you to back up files such as documents, music and videos, and transfer files from one computer to another. While external hard drives vary in storage capacity, they are ideal for storing large files such as videos and animations. Files of this nature consume volumes of hard drive and memory space and are best stored in external hard drives. Whether you are using Windows or Mac OSX, transfer large memory consuming files to your external hard drive quickly and safely. Connect your external hard drive to your computer using the Firewire or USB cable that came with your portable storage device. If its transferring to slow the usb lead might be at fault or you might need a usb 3 card which makes data transfers much faster USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Power on your drive. Some external hard drives do not have a power button, because your computer powers them on automatically using the Firewire or USB cable. Click the Windows "Start" orb and click "Computer" or "My Computer" to launch Windows Explorer if you are using a Windows PC. You should see your external hard drive in the "Drives" section next to the "Local drive (C:)" drive. If you are using a Mac, you should see your external hard drive on the desktop. Double-click your external hard drive to open its hard disk window. If you have any content on your external hard drive, you should see it in this window. Drag files from your computer to your external hard disk's window. Because you are uploading large files, make sure their memory s do not exceed your drive's total memory. Your computer shows a status bar displaying the upload progress for each file you are transferring to your drive. The upload time varies depending on the of the file. Close the hard disk window when you finish uploading the files you want to store, and then click the "Safely Remove Hardware" icon on the System Tray next to the clock, if you are using Windows. The hardware removal window launches. Click your external hard drive's icon in the hardware removal window, and then click "Stop." When prompted, disconnect your external hard drive from your computer. Drag your external hard drive's icon from the desktop to the trash bin on the dock if you are using a Mac. Disconnect your drive from your computer. If you right click in the bottom toolbar select applications to see whats running at the time when transferring the files might be a virus or malware if you see something running that should not be select end now also processes to see what ticking over in the background
Hope this helps b>
b>
Dec 14, 2012 | Hitachi 4TB Touro Desk DX3 USB 3.0 Hard...
Same proble, MS BitLocker is error message.
Bitlocker is available for Vista Business, Enterprise and Ultimate. This gives more security to your data files against unauthorized access. Once bitlocker detects theres a major change of hardware, such as master boot record, motherboard replacememt and such, it thinks that the hard drive is moved to another computer. Usually, bitlocker encryption can be disabled using the USB drive that was used to store the codes for decryption.
Jun 07, 2009 | Dell Inspiron 1501 Notebook
What is the main difference between window XP and VISTA?
Windows Vista & Windows XP
1. Bitlocker Option available Windows XP has . No Bitlocker option
- Bitlocker drive encryption,
Bitlocker on volume
Prevents hard drive from hackers
2. Windows Vista has Windows Defender tool Windows XP has No Windows Defender tool available
- prevents from spyware & unwanted
S/W installing on computer
3. Windows Vista has Parental control Feature Windows XP has No Parental control Feature
- This option enables parents to restrict
Children’s which sites, games .software
to use & not
May 19, 2009 | Microsoft Windows Vista Ultimate Edition
HGST a Western Digital company Hgst Touro Desk 4tb Usb 3.0 Desktop External Hard Drive Black 0s03396 Logo
144 people viewed this question
Top HGST a Western Digital company Computers & Internet Experts
David Payne
David Payne
Are you a HGST a Western Digital company Computer and Internet Expert? Answer questions, earn points and help others
