Question about Midea America Corpimp Mwf1-05cm-bb8 Westpointe Window Air Conditioner
Need replacement control knob for window unit air conditioner
Cannot find any place that has replacement control knobs.
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
The control knob on my Carrier model Vision Aire window air conditioner broke. I'd like to buy a replacement know to control the fan.
Jules, without a correct Model Number (not Vision Aire, that's just a glitzey name), it's hard to steer you in the right direction on where to find the knob. If however, you can come up with a correct model number, you can go to the link below and search for it by your Model Number.
http://www.appliancefactoryparts.com/airconditioners/carrier/carrier-knobs.html
Hope this helped you.
Jul 06, 2011 | Heating & Cooling
My airconditioner will only blow on the floor, i can turn the knob and it wont change.
If this is a wall or window unit, the plastic vanes on the front direct the air flow. If there is a knob to change the AIRFLOW (not the temperature) direction from "down" to "front" or some such, try removing the front panel and see if the control knob has come loose, or see if there is some kind of linkage that has come loose or is broken. Replace broken parts as needed, or fix them if you are able. If this has helped, please rate it accordingly. Good luck.
Jul 15, 2009 | Heating & Cooling
Duo Therm 57915.541
Since you have a knob, I am assuming that this unit has manual controls that are mounted directly below the air conditioner on a ceiling pack. If you smell burned wiring, remove the inside shroud to access the 120VAC connections in the unit. Check these connections for OK, if they look burnt, cut them back and reattach them (be sure to turn the breaker off first). Try the AC again.
If those connections look fine, then remove the upper cover from the unit. Access the capacitors on the side of the unit and check them for ok. If any one of them looks burnt, replace it. These two places are usually the only place that you will get a burned plastic smell.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Control knob
Try Radio Shack. Make sure you first have the shaft dimension
of the appliance that needs the knob. Check the package in the
store before purchasing to make sure it will go on.
Aug 13, 2008 | Heating & Cooling
I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Jul 05, 2008 | Fedders AEQ07FBG Air Conditioner
Master control knob
I am not sure which knob it is. but I believe these are the part numbers for the knobs on your machine.
CRC111404290011, CRC111404290019, 111404290019, 111404290011, 111404290023
Check this link. It shows a thermostat control knob in stock.
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=115657&typeName=air%20conditioner
Jun 30, 2008 | Hampton Bay HBLG5004 Air Conditioner
Midea America Corpimp Mwf1-05cm-bb8 Westpointe Window Air Conditioner Logo
161 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
Shehu Pro
Shehu Pro
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
