Question about HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply
Connect power supply to mother board - HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply
It helps to remove the motherboard to go on power supply connector, and then turns it back on the system board
Posted on Mar 17, 2014
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
The fuse in my BR 300 ATX power supply has blown, what is its replacement part
You need to replace the fuse and dis connect the power supply to the mother board and turn nit back on and if the fuse blowns again then it is the power supply, that is bad, bou if it blowns only when connected to the mother board, the mother has a bad component on it.
Sep 16, 2011 | Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
My s88m g/gl motherboard is not switching on ,but the power supply is working
Power supply is other thing, means she ( Power Supply ) supply the power to *********** board. When mother get the power than she supply all the device. If, *********** board have problem, means not connect properly or burn ( any device ) than she not run. Better you check your all connect device with processor also.
Aug 12, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
