Question about Belkin Surf N300 Wireless Router (722868807347)
Lights which lights should be illuminated?
  • 372 Answers
This router only has 1 network status light
Belkin product page: Link
Quick help guide: Link
Posted on Apr 19, 2013
2003 XKR dashboard illumination goes off when main lights switched on or if dash lights do stay on after starting they go off when main beam is operated.
is this car the all alluminium xk model ? if so it sounds like a bad earth the earth studs are all bonded to the body and are prone to detatching from the body and causing all strange probs. the favorite ones are both front behind the wheel arch liners, if its the older xk still sounds like a bad earth poss behind the headlamps. the only other probs i had was wires coming detatched/poor connection from the column switch, hope this helps
Oct 03, 2016 | 2003 Jaguar Xkr
Electrical
do you mean all warning lights or illumination when main lights turned on ? if its the illumination have you a rheostat switch which dims/brightens dash illumination , see your drivers handbook for location
Apr 22, 2014 | 2006 Ford Bantam 1.3i
AF illuminator
The autofocus system in your camera needs some light in order to be able to see the subject on which to focus. In dim light the camera will light up the illuminator to shed additional light on the subject.
Jun 11, 2013 | Sony Cyber-shot DSC-W710 Black
The light is on but the freezer is not cooling
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
    reaches the correct temperature.
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Apr 04, 2013 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Alarm light isn't illuminating
Lighting or illumination is the deliberate application of light to achieve some aesthetic or practical effect.
if you need a tool you can click here: great tools
Oct 20, 2012 | BMW 325xi Cars & Trucks
Warning lights remain illuminated, Alero
First check for error codes (DTCs) to see if you can determine the problem.
Apr 16, 2017 | 2000 Oldsmobile Alero
While i was driving on highway my abs light and traction control light became illuminated.both stay illuminated while car is in drive.when first starting car the lights are not illuminated.Two days later...
I've had the same type problems before and it turned out to be caused by my weakening alternator, if able to do so I would suggest, to begin ruling out causes, remove the alternator and take it to an auto parts store that offers free testing and have the test performed.
Jan 27, 2011 | Lincoln LS Cars & Trucks
I have a 2000 Jeep Wrangler Trouble Symptoms: -When lights are on, brake lights (all three) remain illuminated and only flicker when brake pedal is depressed. Facts: -With lights off, dashboard lights...
sounds like wireing is shorted together. you need to trace down wires and check for bad spots in wireing. also be sure and check plug if you are set up for trailer lights.
Feb 13, 2010 | 1990 Jeep Wrangler
Light
From left to right
1. The wrench light is the service interval light.It will illuminate after about 4800 miles or 358 days to remind you your vehicle is due for service.To reset hold the SELECT and UNITS buttons on the trip computer for 5 secs. The light will illuminate then extinguish itself after about 4 secs.
2. Frost warning light. This light illuminates yellow when exterior temps are between 39 to 32 deg. F to warn you of possible icing on the roads.It will illuminate red if temps drop below 32 Deg.
3. Brake pad warning. Will illuminate when brake pads have worn down to the sensors in the pads.
4. Washer fluid warning.
5. Door Ad-jar
6. Bulb failure. Indicates an exterior bulb is out.This will illuminate until brake pedal is pressed after starting engine unless of course one of the brake lamp bulbs is burnt out.
Feb 26, 2009 | 1999 Mercury Cougar
Button illumination
Check see if your illuminate wire(orange) is connected properly. If it is, you should get a high illumination when your lights are off and low illumination when lights are on.
Mar 06, 2008 | Eclipse AVN5500 Car DVD Player
Belkin Surf N300 Wireless Router (722868807347) Logo
32 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
