Question about Kenwood Tk-630h Tk-730h Tk-830h Tk-690h Tk-790h Tk-890h
Have a TK 690 will power up and recivice will not transmitt sometimes tx light will come on other times not, Even when light not on will almost be like open mike. When installed did radio check and all was fine now have issues
I need help programming my tk-690 / tk 790 dual head dual band
Try this: join yahoo group Specific to your radio Make/Model, apart from great info you can download manuals, schematics and other goodies for your radio, all this is free.
Note: Re:- Downloads, only if available!!!
I hope this helps you with your query.
Cheers,
Peter
Mar 09, 2013 | Kenwood Kpg-44d 2.03 Radio Programming...
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
I bought a Kenwood model TK 8102/TK 7102 how do i program it?
I bought Kenwood TK 7102 VHF radio, but it was programmed and I can listen the dispatcher but can not transmit to him. Any solution please help.
Aug 20, 2010 | Kenwood TK-3101 Radio
Light on refirgerator side doesn't come on unless I tap switch.
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Sep 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
My cobra 29ltd cb radio will power on and recieve but will not transmitt. the transmitt light lights up but the meter will not move. what can I check?
I am assuming you have called out for a radio check and not gotten a reply, or even better tested it with friends radio. Just because the meter doesn't mover doesn't mean that its not transmitting.
So as long as you tested it with another radio, and it is not transmitting it could be any number of things. If you have never had antenna tuned so the swr is low, or your swr was high for a long time, your final transistor is most likely blown.
TX switching transistor could be blown, trace could be gummed up.
If your ant light is coming on, the is a problem with your antenna. Could be disconnected, and that can lead to a blown final.
At any rate, your problem most likely requires a tech. Take it to a repair shop.
Sep 27, 2009 | Cobra 29 LTD CB Radio
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
My cobra hh-36st cb radio is stuck in TX mode. The RX/TX light is red each time it is truned on. Removing and replacing the batteries has not worked.
G'day,
I think your problem with the Cobra cb is in the microphone, you should have a plug on the Mic cord end ,try disconnecting this from the CB unit and see if it clears it self. If this does the trick your problem is in the Mic it self, or the cord has a fault in it. However if you still have a problem it may be that the transmitt/ receive relay located in the Cb is stuck on transmitt, sometimes this can be cleared by tapping the case with the handle of a screw driver, place towel on the case first to stop any damage to the case( this doe's not always work) you may in this case need to have it serviced
all the best hope I have been of help,
John
Apr 08, 2009 | Cobra Radio Communications
TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Jan 25, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Kenwood Tk-630h Tk-730h Tk-830h Tk-690h Tk-790h Tk-890h Logo
75 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
