Question about Lanier 117-0289 Genuine 5625/5631/5706/5806 Cyan Laser Toner Cartridges 1170289
Problem with my lanier power - Lanier 117-0289 Genuine 5625/5631/5706/5806 Cyan Laser Toner Cartridges 1170289
Lanier 5518 with a sc541 code
To clear enter service mode and cycle power,(push in sequence clear modes(yellow) 1 0 7 then hold the stop(red) for 5 seconds) -Carl
Jan 20, 2015 | Lanier 5515, 5518, 5618, Ld013 Fuser Kit
Lanier 5618 Network
Lanier 5618 is not a Network Copier. However, it may be installed on one PC and shared from there. Drivers are available from LANIER Official Support
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 22, 2011 | Lanier 1205 Copier
I HAVE THE LANIER VW 110 TRANSCRIBER; I PLUG IT IN AND GET NOTHING. COULD MY POWER CORD BE BAD?
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
Apr 14, 2011 | Lanier VW-160D
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Got a function code SC322 on lanier 5622 copier. Power cleared the unit several times but status remains unchanged.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
Sep 15, 2010 | Lanier Office Equipment & Supplies
LANIER COLOR COPIER MODEL LD345c Funtional Problem SC541
sc541 means no warm up, press the clear modees the punch in107 then press and hold down the clear stop key untilk it goes into sevice mode then shut main power
Apr 07, 2010 | Lanier 1205 Copier
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
Lanier VW110 won't play
yes I have two lanier voice recorders one left hand and one right hand one power supply real cheap do not use them any more . listed on ebay as lanier vw-110 standard cassette dictator. If you still need them. Thank you John
Jan 10, 2008 | Lanier Audio Players & Recorders
Lanier 117-0289 Genuine 5625/5631/5706/5806 Cyan Laser Toner Cartridges 1170289 Logo
20 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
