Question about Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF 15PPM Printer
Line on documents run through ADF on Xerox DocuMate 515
Line appears on scanned documents, not on those created on the PC from a file.
    New Friend:
  • 77 Answers
Check if it is from the glass plate and ADF.
If only ADF check the small glass plate to the left of the big one.
Clean that and it should disappear
Posted on May 30, 2013
  • Shelley Woike May 30, 2013
    Thanks Paul, that was the solution!
SOURCE: my Xerox Documate 510 adds
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Posted on Mar 05, 2009
  • 12 Answers
SOURCE: Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Posted on Aug 21, 2009
  • 7 Answers
SOURCE: Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Posted on Jan 10, 2010
dlopez762
  • 34 Answers
SOURCE: i need the drive gear for the adf on a xerox
Hello.
I am a Support Engineer with Xerox Scanners.
We do not make a scanner with the model number 636.
If you are referring to the DocuMate 632, the drive gear on the ADF roller is available in the roller replacement kit (attached to the ADF roller, not separately). You can order that kit here.
On the other hand, if you are referring to one of the gears in the ADF housing, the device will need to be sent in for service.
If you continue to experience trouble or have any questions, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Posted on Sep 28, 2012
dlopez762
  • 34 Answers
SOURCE: XEROX DOCUMATE 510
Hello.
There would have been an extra pad in the original box that the scanner came in. If you no longer have this pad, you can order the maintenance kit here. This kit will also include the necessary components to clean the feed rollers.
If the feed rollers are worn out, you will need to have the scanner serviced.
Please contact us to discuss your service or replacement options by calling 800-648-0410.
Regards,
Xerox documate 752
Your document must be in place/position to be scanned, faxed, etc.
Place document, then scan. ADF is your automatic document feeder. Used when copying/scanning multiple pages. Reload and try again.
Aug 29, 2013 | Sewing Machines
I have a problem with the Xerxox documate 515 error messge" copy of prtection failure. There is no VRS file- import dongle connected." remove all sccanner software and reinstalled, but same...
it seems that the drivers did no install correctly.
-Go to the control panel -> Programs -> add/ remove programs. -Then uninstall Kofax VirtualReScan and restart the computer. -After the computer comes back on insert the installation disk and reinstall the drivers.
If the problem persists maybe your installation disk is corrupted, try to download the latest version from xerox and try again.
http://www.xeroxscanners.com/en/us/products/drivers.asp?PN=DM515
Mar 21, 2011 | Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF...
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
A line keeps showing up on the scans that's not on the documents...how do I delete the line that isn't on the original document but shows up about 1-2" in front left side of scan?
All it takes is a minute speck on the glass when using the ADF to cause lines on a copy.
THOUROUGHLY clean the glass including the thin piece to the left of the bed if there is one.
Spray glass cleaner on a link free cloth and wipe it clean
Jan 07, 2011 | Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF...
I am getting an error that says '' copy of prtection failure. There is no VRS file- import dongle connected.
You have a corrupted VRS setup - did you try to update the driver? The only way I could fix this problem was to uninstall all the scanner software (OneTouch, OmniPage, Driver and PaperPort) using the Control Panel, remove the \windows\Pixtran directory, run CCleaner's registry cleanup (might not be necessary) and reinstall the scanner software from the Xerox installation DVD. Took me the best part of one day to figure this out.
Nov 23, 2009 | Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF...
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on...
Jan 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Jul 16, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 515 SIMPLEX-FLTBF W/ ADF 15PPM Printer Logo
148 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
