Question about Pioneer AVIC-F900BT Car GPS Receiver
I have an F900BT that is also in a constant rebooting loop for the past 2 weeks. Worked great for years now won't stop rebooting. I've tried to follow instructions on updating and fixing reb
F900BT constant reboot loop. Can't find all necessary updates online.....
SOURCE: i have the same problem but i have AVIC F700BT it keeps rebooting
go to the AVIC411.com they can answer a bunch of your questions.
Posted on Oct 27, 2009
SOURCE: I have a Pioneer AVIC-F900BT
It might help to turn of 'using camera'
Posted on Dec 19, 2010
supernova278
  • 1932 Answers
SOURCE: pioneer AVIC-F900BT over 2 years
The latest software for this 3.0.
To check the firmware your system is using
1.Switch on your Navigation unit by switching on the ignition of your car. If you don't see "Top Menu" displayed on top of the display, press the "MENU" button
2. Select "Settings"
3. Select "System Settings"
4. Select "Service Information"
5. You should see:
· Map version: 01.xxxxxx
· Version: 2.xxxxxx
If it is 3.0 then no need to update.That is latest thng you have.If it is 2.0 or less you need to update.
Thank You
Posted on Jan 05, 2011
Ezrahite
  • 2632 Answers
SOURCE: Pioneer Avic F900BT Screen says
Welcome to Fixya. You can try to use the video below and see it if it will be fixed. The instruction was also included. You can download the TestMode here avic411.com
Thanks for using Fixya.
Posted on Mar 25, 2011
injunearing
  • 81 Answers
SOURCE: my system loads up but reboots constantly....the
My question to you is ...Has the system ever operated correctly? If so then the problem most likely is in the head unit. So assuming that it has never worked correctly, I would say that you need to verify that the B+ is a direct connection to the battery. Something tells me that you have utilized a wire that is common to the neutral safety switch. Put the car in neutral to test for this. There are some other things you can do.Treat the system like a computer system with a hardware conflict. Disconnect ALL devices that are connected to the unit including the speakers and try turning it on with everything disconnected. Understand that this system is only to be used with IPODS that are 3rd gen and newer. Not all usb devices are compatible with all systems. I believe there is also a "Test Mode" the unit might be stuck in, look into that
Posted on Jun 08, 2011
Testimonial: "Thanks a lot "
Samsung Charater Not Working!!
There is a simple answer to this and that is to replace the phones digitizer or touch screen and your problem solved.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/james_7e1192bbb9f949fa
May 02, 2013 | Cell Phones
Car completely dying, have temporary solution but would like a more permanent one.
I would replace starter with solonid . I believe your solonid is bad. if you find this helpfull please leave me great feedback
Feb 17, 2013 | 2005 Ford Taurus
WMA stream on a constant loop for my favourite radio station
Since other stations worked perfectly, perhaps the other station was streaming a loop.
Otherwise try this: Support Cobra Electronics Corporation
Mar 21, 2017 | Cobra Radio Communications
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
Sep 21, 2011 | Gateway GT5654 Desktop PC
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
I have a pioneer avic-f900bt and it keep turning off. it powers up for a couple of seconds and then it shuts off what could that be please help me.
I appear to have the same issue with mine. I purchased mine from Audio Itch in Tampa, Fl in December of 2008 and had them install it with an amp and speakers. Worked fine for almost exactly a year. Upon starting up my car, it powered up and gave the system powering up notice, then went blank. Rebooting with the small restart pinhole button sometimes works, but most of the time it will start powering up again, then shut off????
Mar 07, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
Pioneer AVIC-F900BT Car GPS Receiver Logo
141 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
