Question about U-Line Icemaker
I have a uline clr 60ss will not run after replaceing pump and contral board
2 Suggested Answers
  • 286 Answers
SOURCE: I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
Posted on Aug 09, 2009
I have a CLR 1215S uline icemaker it is not making ice and there is a code on display S or 5
According to the service manual it is saying that the #1 thermister needs to have is offset adjusted and that you need to contact their tech line for assistance. 800-779-2547
Oct 03, 2017 | Ice Kitchen Appliances - Others
Need to replace circuit board, how do i?
take screws out pull old board out put new one in
May 24, 2014 | ULINE U-Line 2175BEVCS-00 2000 Series 24"...
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
Aug 08, 2009 | U-Line Refrigerator Ice Maker
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Humidifiter doesn't humidify
have you checked the misting nozzle? if its clogged place it in (CLR) and let soak, I would try to run a little diluted (CLR) through the unit as well, to remove any calcium build up, that is the most common problem with most humidifiers, also check to make sure the pump is working, if not you will need to replace the pump, hope that helped
Jan 18, 2009 | Sharper Image SI491 Humidifier
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Dec 23, 2008 | U-Line Icemaker
U-Line Icemaker Logo
91 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
