Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Why isn't the carborator not getting gas? - Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
    New Friend:
  • 15 Answers
If mower has been sitting the jets could be clogged up or float my be stuck. if mower is used often there may be a hole or rip in primer bulb
Posted on Nov 21, 2013
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
McColloch 7800 generator leaking fuel from the carborator.
rebuild carb using new needle and float if float is full of gas and sinking
Sep 17, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
I am having fluchuating idle & bucking like running out of gas
Hi Bill,
This is the clear indication of the following.
1. You carborator is choked
2. Improper mixture of fuel and air
3. Choked exaust pipe
Solutions:
1. Clean your carborator and air fileters
2. Tune your idling screw to make proper mixture of fuel and air get's into the engine
3. Check and de-carbonate your exaust pipe.
Hope this will help you.
Regards,
Nat
Jul 01, 2012 | Motorcycles
Sears intek 20 hp, fresh gas, filters air and gas, oil, and plug still won't start where should small valve and screw adjustment be set to, may be the problem don't know. won't stay running...
If you have not been putting gas treatment in your gas to treat the ethenol they have been putting into the gas its a good chance its the needle valve in the carborator. If you live in a state that does not add ethenol to the gas disregard this advise.
Jul 10, 2011 | Garden
I have used my mower 3 times and it is leaking gas out of the carborator faster than i can put it in.
You have water in your gas tank or gas in your carburator float or a needle valve that isn't seated correctly. First empty the gas in your fuel tank into a clear container. If their is water ,you will see it with the gas. Second remove the bowl from the bottom of the carburator careful of the gasket, check for water in the bowl, clean bowl. Carefully remove float and needle valve. Shake float, listen for liquid inside. Check tip of needle valve for damage or corrossion. These three examples should be one or all of your problem. Clean and reinstall all parts. Add fresh gas and you should be ok. GOOD LUCK.
Jun 30, 2011 | Troy Bilt 5.5hp Self Propelled Mower
1982 yamaha yz490, I checked the fuel flow and all is good? It has 120 psi compression? And I put a new plug in but still wants to run for a few seconds then die? When it's not running It also leaks...
If it's leaking from the bowl drain, the drain screw isn't seating in the drain hole. Shut the gas off, pull it out and clean the tapered seat it seals in. I know you said you cleaned the carb, but if the float needle isn't seating, it would leak out the overflow and flood out the carb as well. Check out the float-if it's brass, shake it and listen for gas inside. If it's plastic, put it in a cup of gas and see if it floats. They do get saturated over time and need to be replaced. Good luck!
Jun 14, 2011 | Yamaha Fuoco Centenario Motorcycles
Won't stay started, spitting black oil from carborator
there is to much oil in it . find fillplug remove some oil w/straw until it stop comeing out carb
May 07, 2009 | Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
118 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
