I just bought a double wide trailer, what are the correct filters to use in the AC & where do they go
What kind of A/C filter are you suppose to use in a mobile home with intertherm heating and cooling system? and where does it go?
  • 659 Answers
SOURCE: Changing Air Filter
In general terms an electric unit uses a 20 x 20 x 1 filter and a gas system uses a 20 x 25 x 1 filter. If the return filter is somewhere other than at the unit, it will very greatly in size. Its the descretion of the installer as to what size filter they choose to install.
Posted on Apr 07, 2009
pierre1811
  • 144 Answers
SOURCE: Where do the filters go on the Intertherm MGH055AB?
The filters on an Intertherm usually go on the inside of the front panel
Posted on Mar 06, 2009
philbran
  • 242 Answers
SOURCE: Should I have a return air grill with a filter?
if the closet the inside unit is in is vented to the house the filter should be inside the unit at the top or bottom.
Phil
Posted on Jun 09, 2009
  • 334 Answers
SOURCE: My son just moved into adoublewide mobile home.
The filter is either going to be in the indoor unit or it will be in a return grill in the wall or ceiling. If it is just the thermostat saying that, let me know the make and model of the thermostat and I will tell you how to reset it. Make sure you find and change the filter anyway, that needs to be done on a regular basis.
seth
Posted on Jun 27, 2009
  • 415 Answers
SOURCE: Where are the filters located on the Intertherm
There are a couple of places to start looking.......the first place is in the return grille. If it is not in the return grille, then the filter should be in the Intertherm unit itself.......look for an access panel marked "filter".
Posted on May 18, 2010
Ac unit does not have anything to hold filter in place
Assuming you are talking about a residence unit, the filter is supposed to have a wire mesh on one side. This mesh is to prevent paper-alike filter getting sucked in. Filters have arrow-marks for air-flow, double check that.
Sep 29, 2012 | Heating & Cooling
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Jun 10, 2010 | Heating & Cooling
Where do I get filters for my Airwell Airconditioner?
take down the dimensions of the air filter. like 16" wide x 20" long x 1" thick. the go to your local hardware store. or lowes, home depot hope this helps.
Jun 13, 2009 | Heating & Cooling
Same problem. Can't find the AC filter location inside. Can it be in the engine compartment?
This is under the dash on the drivers side. Look for a cover about 10 inches long, 1 inch wide. Slide clip to open, pull filter down & out.
Jun 05, 2009 | 2007 Dodge Grand Caravan SXT Minivan
OIL CHANGE, NOW ITS KNOCKIN
You were supposed to put 4 ounces into the filter before installation to prime the system.
May 22, 2009 | 2003 Harley Davidson XL 1200 S Sportster...
Transmission Cooler for 2008 Honda Accord
The best cooler to buy is one that looks like an AC condensor, very dense cooling fins, and buy twice the capacity you plan to tow, you are at the very edge of the weight limit for your car, so be easy on the brakes, also top of the trans after you install the cooler, make sure the trans is hot when you check the level.
Jul 30, 2008 | 1992 Honda Accord
Trailer lights quit working
Double check your connection and then check your fuses. Make sure the lights are grounded too. They won't work if they aren't.
Jul 07, 2008 | 1999 Dodge Grand Caravan
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
