Question about Briggs & Stratton Garden
Small engine hesitates on start after worm up it runs ok
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Thats common for motors to hesitate till they warm up but you can adjust your carb for more fuel flow this take care of hesitation
Posted on Jun 07, 2014
Just rebuilt carb, runs OK but needs some adjusting. where should start?
Sometimes hesitation means a vacuum leak. Check all hoses to the carburetor and also cap any unused connection tabs. The cap is usually a small rubber cap that slips over a tab.
Mar 20, 2016 | Cars & Trucks
I have a 02 Grand caravan that has new radiator, termostat, one new fan. the temp gauge goes up to max hot the drops right back down in seconds. what could be the problem?
it could be you have an air lock in the cooling system
remove the rad cap from the rad, start the engine and let it run until the coolant drops (add to fill it back up) or until the coolant boils out of the rad spout.
maybe pull the heat sensor. -replace it OR clean it off, reinstall it.
Mar 12, 2015 | 2002 Dodge Grand Caravan
Car starts and run no power
Could be one of a few possible problems,could be a plugged catalytic converter,a bad ignition coil with the spark jumping out the side of it instead of the terminal or even low fuel pressure or could have jumped time on the timing belt.what engine is in it? how many miles are on it? have you had the timing belt replaced? tune up? biggest question i have is..does is accel better when pushing the pedal slowly but breaks up pretty bad under hard acceleration? if it does-try a tune up (plugs,wires) just to start with to see if it helps
Apr 04, 2014 | 1994 Toyota Camry
Engine cut of when engin get worm in ford falcon 2000
HAVE YOU CHECKED AT ALL WHETHER IS THE FUEL PUMP ITSELF,OR FUEL PRESSURE DROPPED,OR ANY FUEL FILTER
BLOGGED? GOOD LUCK.
Nov 06, 2013 | Cars & Trucks
Starts & runs ok when cold , starts to run poorly as it warms up
Is the check engine light on ?
Has anyone checked the fuel pressure cold and hot ?
Feb 18, 2013 | 1991 Buick Park Avenue
I have a 2002 Neon (MTX), My speedo died, I troubleshooted all the way down to the ******, replaced the speedo drive gear and a bearing. Filled ****** with fluid, started car after all engine components...
Try a bigger battery or a battery charger.swap it to give enough power to start the engine. If that doesnt work than try checking the starter solenoid at your local auto store
Nov 11, 2012 | 2002 Dodge Neon
Fuel injection problem
carb needs cleaning, you may have a air leak. spark plugs being fouled up , and might even have timing out. there is 2 jets or more in the carb if there is a problem it can weaken fuel having choke on can give it more air and fuel. depending on model of engine. on fuel in line there will be a filter, very small these can get damaged and let sludge from the tank in. clean out the carb remove it and open it up clean out and you will see brass like screws blow them out with an air line, refit with new seals, you can make them if they not available. or you a sealer thats for fuel.. air lines you can spray them while engine is running and if engine pitch changes that can be were the air leak is.
May 28, 2017 | Cars & Trucks
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Tempreture gauge drops to cold and car stops
Sounds like faulty engine temp sensor. When it drops to cold, the engine control unit picks this up and alters the fuel mixture accordingly. The ECU will be making it a very rich fuel mixture for cold starting, hence very poor running when engine is hot.
TL
Jan 12, 2009 | 2006 Renault 181
Fuel
HI
THE PROBLEM IN THE(ECT) ENGINE COOLANT TEMPERATURE SENSOR ITS IN THE ENGINE ROOM NEAR THE THERMOSTAT WHEN IT COLD THE ENGINE TAKE THE FUEL AND START UP BUT WHEN THE ENGINE WORM UP THE FUEL IS TOO MUCH AND AFTER HOURS THE ENGINE BE COLD AND NEED TOO MUCH FUEL TO RUN
TEST THE (ECT) BY DIAGNOSES DEVICE OR BY (AVO METER) IT RANG 2,5 VOLT WHEN COLD TO 1,1 VOLT WHEN WORM UP
IF IT OK THE PROBLEM IN THE FUEL INJECTORS HAVE A LEAK FUEL IN IT
Jun 28, 2008 | 2000 Hyundai Elantra
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
