Question about Hotpoint Washing Machines
Every time i plug my washing machine in it keeps tripping my fusebox out i have tried every socket in the flat
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
SOURCE: Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Posted on Feb 08, 2009
ginko
  • 19396 Answers
SOURCE: my washing machine keeps blowing he fuse in the plug
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
Posted on Apr 13, 2009
SOURCE: My hotpoint wf860 washing machine has no power!
hi guys
Posted on Jun 16, 2009
  • 850 Answers
SOURCE: Trying to locate fuse in washing machine
if it bows the mains then dont try it again!
get it checked out ASAP!
Posted on Jul 26, 2009
Hoover primera washing machine keeps tripping electrics when tured on.
Possible that there is higher current drain which trips off the circuit. This can be due to moisture or dampness in the circuit , coils or the motor. You need to remove the top panel and dry using a dryer. check the connectors, check the main line , the motor circuit. Isolation of the motor or the heater can confirm the short if the circuit stays. Check the main power to the panel and allied circuit for possible capacitor leak or short.
Mar 16, 2013 | Washing Machines
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
Washing machine blowing trip?
It is best to disconnect the mains lines from the control panel to the different section, which are the motor, heater, inlet and outlet valve pump. If the fuse trips then the fault is the control panel board and could be a failure of the rectifier or SMPS driver. You might need to replace the board.
Jul 04, 2012 | Washing Machines
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Machine tripped all sockets halfway through cycle
Hi.
You are going to have find the problem by elimination.
Start by unplugging the motor. and trying it again,if it still does it then you need to disconnect heater and so on, until it stops tripping
Nov 24, 2008 | Washing Machines
Hoover VHD Washing machine
Surely it is the wall socket.
Mar 19, 2008 | Washing Machines
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
