How do i reset my freeview on my jvc interiart 32
Jvc interiart musee 25
I'd personally look at getting it replaced either through a warranty claim or new purchase
Jul 24, 2014 | Televison & Video
Jvc interiart television
hook up box to a stereo thur av jacks if it dod it thur stereo then its not your tv its your sky
Sep 19, 2013 | Televison & Video
JVC Interiart Sound Problems
What is the problem you faces with it. Please provide more details.
Oct 15, 2012 | JVC Televison & Video
Hi I have a JVC 32 inch HD television. When I am on HDMI1 (freeview box in on) or HDMI2 (playstation is on) it will keep going to a blue screen every few minutes. How do I stop this from happening? I
Make a hard reset to this TV. Unplug it from AC mains wall socket. Wait for 5 minutes or so. Plug it again. If this do not help you, seek tech support.
May 29, 2012 | JVC Televison & Video
Im in Sri Lanka. I have a 29" JVC InteriArt Musee TV. It's Very Good Television. But is in sometime FLIYBACK wire High voltage Spark. is Very Dangerous Sounds and looking Spark. I think replace TV...
With an EHT meter, check the EHT voltage is no higher than 26kV. Check where the spark is coming from, thoroughly clean the area with Isopropyl. If on the EHT plug, on the tube, use DC4 silicon grease on the affected area.
If on the transformer, use a liberal amount of DC4 to stop the sparking.
Mar 05, 2018 | Televison & Video
JVC Interiart 27" TV
Hey there Andy l rekon ya busted yer remote so best git on down to the store an git yerself one a them universal remotes for xmas.
Nov 17, 2017 | JVC AV-27D302 27" TV
JVC InteriArt 32 inch conventional TV 3 years old- no warranty. TV is switching off and coming back on every 57 secs. Lose about two to three seconds sound and vision. Checked to see if sleep timer was...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
May 08, 2017 | JVC Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
