I have a Maytag Bravos washer model MVWB950YGO, the clothes always come out extremly wrinkled no matter what temp setting i use???
I have tried numerous settings and different cycle settings including cold water wash,
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
Joe Onley
  • 363 Answers
SOURCE: Kenmore Washer Model#23922200 does not spin
I assume this is an older top loader. You may have something stuck in the pump itself. I can tell you how to check this. Following is cabinet removal instructions:
  • Using a Phillips screwdriver, remove the screw from each side of the console.
  • Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top.
  • Lift the console up and lay it on its back.
  • Unplug the harness connectorfor the lid switch.
  • Insert a flat screwdriver into the front edge of the clip (located on both sides), and pry back. Remove both clips from the holes in the cabinet and slide down the other end of the clips and out the slot in the rear panel.
  • Open and hold the lid while grabbing the cabinet front opening. Be sure when tilting the cabinet that the back edge clears the vacuum break.
  • Tilt the top of the cabinet toward you by pulling on the lid and opening of the cabinet. This releases the back slots of the cabinet from the tabs in the back of the base.
  • Carefully pull the cabinet away from the base of the washer and set it aside.
    Now you have access to most of the parts.
Now in front of you on bottom is the pump. It's usually white in color. Without taking it off the motor, make sure it is someplace where you can let the water run out of the machine. Remove the clamp from the wash tub to the pump and look inside. There may be a small garment or something similar inside. You can use a small needle nose plier to get to this and remove it. Reattach the hose and close the cabinet in reverse order.
Hope this helps you
Joe
Posted on Aug 30, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
Posted on Dec 13, 2009
  • 41 Answers
SOURCE: whirlpool awm 221 washer
you will need a replacement heating element for the appliance
Posted on Jun 12, 2010
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
All my dark clothes have soap deposits on them and clothes seem exceptionally wrinkled when I take them out of the washer.
If load is wrinkled the load may have set in the washer to long it is recommended to remove wash as soon as it stops or the load was too large for the washer capacity. Loads must be balanced and move freely during washing. Also using too much detergent could cause the deposits on clothing. Using an he ( high Efficiency) detergent might help. Using delicate or another cycle with low spin speed will reduce wrinkling.hope this helps
Jul 01, 2015 | Maytag Bravos MTW6600T Top Load Washer
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
Jan 02, 2015 | Crosley Washing Machines
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
I have a Cabrio platinum top loader (not glass) & dark clothes come out with white powdery residue no matter how little he detergent I use and clothes come out really wrinkled
Aha! the problem i'll guess your model number is wtw8200ywo-you have a very bad washing machine-i'm sorry-it does what you say darks are covered withresidue and clothes are very wrinkled-if you are not happy with these issues take it back and get another brand of washer-I have a maytag-maytag was bought by whirlpool-I've had problems with this machine only a year and a half old so probably not a good choice either-Research before you buy and let me know who you come out-cheers Denny
Oct 22, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Close very wrinkled
I have the same problem with clothes being very wrinkled and clumped together after a full cycle. I believe it is not because of the spin cycle, but because the washer using very little water to wash the clothes, so they bunch up easily and are not free flowing. NOW, I try to use the cycle that uses the "Deep Clean" action or I activate it manually with all other cycles. It adds more water to the cycles and the clothes come out wrinkled, but not as much. Try it.
Feb 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag washer is a bit older its a Dependable Care model 3cycle
The agitation problem is probably caused by a bad timer. Also, on the wrinkling issue, be sure that your hoses are connected right (hot to hot, cold to cold). Have found out that if they are switched, you would wash in wrong temp. Doubt that a hose would cause problems because washer wont start unless the proper amount of water is in the tub (also could be a timer problem). Good Luck!!! Jim
Sep 08, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
