Question about Ford Vehicle Parts & Accessories
How do you take interior panels for the purpose of removing the shocks
Skocks
  • 458 Answers
What year? What model? Sedan,coupe,wagon,hatchback?
Posted on Oct 08, 2013
There is a piece of cardboard inside covering a metal panel, do I need to remove it?
Interior of microwave ovens are metal, never cardboard. Must be something used for shipping purposes, pitch it.
Jun 17, 2015 | Microwave Ovens
Tip
When should I replace my shocks and or struts When a vehicle is brought into an...
When a vehicle is brought into an auto repair shop for routine vehicle maintenance, the auto technician may suggest that the vehicle shocks or struts need to be replaced. Learn the function of a car or trucks shocks and struts. Find out why the shocks and struts need to be replaced and how someone can tell if they’re bad.
The Purpose or Function of a Cars Shocks and Struts
Shocks and struts serve the same purpose. They’re main function is to keep the vehicle from bouncing. A vehicle has front and rear springs to cushion the vehicle over rough road conditions. If there were no shocks or struts the vehicle would continue to bounce excessively. The shocks and struts prevent the car from bouncing by damping the springs.
What’s the Difference Between Shocks and Struts?
Shocks are usually used to dampen leaf springs, where as a strut is used to dampen coil springs. Shocks are usually a single cylinder in the open where as a strut is normally surrounded by the coil spring and are more massive and complicated.
That’s why struts normally cost a lot more to replace than a shock. On a car the front suspension usually has struts and the rear usually has shocks. Some trucks have shocks on the front and rear. Other than those distinctions, shocks and struts serve exactly the same purpose.
Why Should the Cars Shocks or Struts be replaced?
Keeping in mind that the purpose of shocks and struts is to keep the vehicle from bouncing, the following is some of the reasons why they should be replaced.
* An excessively bouncing car can be an uncomfortable driving experience.
* The vehicle can be harder to control leading to an unsafe condition.
* Excessive strain can be put on other vehicle components causing premature failure.
* Bad shocks or struts will cause the tires to bounce and create spotty or choppy wear on the vehicles tires.
How to Tell if a Cars Shocks or Struts are Bad
1. Shocks and struts can be oil or air filled. If they are leaking oil or air they need to be replaced. Consumer beware, some dishonest auto repair shops will squirt oil on the shocks, show the customer the leaky shocks and tell them they need to be replaced.
2. Another method is the bounce test. Put all your weight on the front or rear of the vehicle and push down on the vehicle. Let go of the vehicle and stand back to see of it bounces. If the vehicle comes back up without bouncing, the shocks are probably in good shape. If the vehicle bounces a few times, chances are the shocks or struts need to be replaced.
Shocks and struts are wear items, not maintenance items. There’s no set mileage or time limit when they should be replaced. If the tires seem to have a choppy wear pattern or the vehicle bounces excessively over bumps, the shocks need to be checked.
Look at the struts or shocks and see if they’re leaking. Perform the bounce test and see if the vehicle bounces. Replacing the vehicle shocks and struts when they’re bad will create a safer and more comfortable driving experience, not to mention saving money in the long run.
on Dec 14, 2009 | Honda Accord Cars & Trucks
How to remove interior rear quarter panel on 2006 escape so shock can be replaced
Jack it up and place on stand, remove wheel, remove all screws holding panel in, remove panel.
Dec 10, 2014 | 2006 Ford Escape
How to remove rear struts from a Mazda CX-9?
fold rear seats forward and remove the small panel , this will reveal the top nut
Jun 17, 2014 | 2008 Mazda Cx 9
I have a helper spring and trauck air bags fitted. still the rear tray bounces lots every time I go over bumps - very distracting when hard driving on sandy beach. could it be old shocks? or are the...
Yes its old shocks,the purpose of the shock is to slow down and control the rapid movement of the spring . The purpose of the spring is to control your ride height. If your vehicle is sagging the spring is no longer supporting the proper ride height and is considered worn and will need replacement. As for the bumpy there are all type of shocks designed for comfort, stiff or soft,
Apr 26, 2011 | Ford F-150 Cars & Trucks
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Battery drains if interior light fuse is plugged into fuse box.
I'd remove panel as/if necessary so that I could remove connector at power trunk latch, and see what happens from there. If interior lights work o.k. and no drain, then you found your source of drain/short.
Jan 31, 2010 | 2004 Suzuki Forenza
How do i replace an air shock on 2002 bonneville
did this today. went to advance auto parts, purchased monroe replacements air shocks. removed interior trim in trunk to gain access to upper retaining nut on shock. removed 2 retaining nuts at bottom end of shock. attached new air line just as i removed from old shock. inflate, done.
Jul 10, 2009 | 2002 Pontiac Bonneville
* * * Removal of Interior Trim Panel * * *
There are 2 finish covers on each side,looks like the one on the left is directly over ash tray?
You have to remove these 2 covers and there will be a screw located there. Remove these 2 screws remove the upper center finish panel by pulling outward to release the panel retaining clips.
Jan 30, 2009 | 2008 Ford F 250 Super Duty 4WD
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
