Question about RCA F19430 19" TV
How to tell if a fuse is blown? - RCA F19430 19" TV
    Problem Solver:
  • 12 Answers
Make sure to unplug tv from outlet and wait 5min. take the back of tv off and you should see 1 or 2 fuses. test with multi meter
Posted on Apr 18, 2013
How can I tell if my blower can fuse is blown on my 2001 sunrise the fuse u see the hood! I xont know how to tell if it is blown
The fuse of which you speak should have two metal tabs that press into the two slots holding it.
The part you see should be clear colored plastic.
Between the two "spades" that plug in, is a piece of wire the shape of an inchworm.
That metal should be burned into two parts if it is blown.
Know, however, a fuse can be no good and still look good.
Try some replacements.
God bless your efforts.
Nov 10, 2016 | 2001 Pontiac Sunfire
Where are fuses located and how to tell if one is blown
Fuses are usually inside on the circuit board. A blown fuse is usually burnt, so it will be visible. If you are not sure, you can remove it at hold it up to a light. You should see a small wire inside the fuse. If it is blown, you will see a break in the wire. Keep in mind, a blown fuse indicates something is wrong. If it blows again, have it tested by a electronic technician.
Feb 04, 2016 | RCA RTD317W, DVD Home Theater System with...
How can you tell when a fuse is blown under the hood Can you show pictures I want to see this is supposed to look like
Hi Lisa.
The specifics of where your fuse panel(s) is/are will depend a lot on the make and model of your car. There is often one panel in the passenger compartment, and one in the engine compartment. This WikiHow page does a pretty good step buy step of identifying panels and locating / testing fuses for if they're blown: How to Check Fuses
This is an example pic of good vs blown fuse:
image blown automotive fuse Google Search
Good Luck and Happy Holidays!
D
Dec 09, 2015 | Cars & Trucks
How to tell if fuse is blown
Does it have a fuse?
If it has, you can have it a look and tell if problem is a blown fuse
If there is no fuse, you should take it to repair
Jun 07, 2015 | Audio Players & Recorders
I have a 1991 gmc sonoma but the cigarette doesnt work can anyone tell me what fuse controls it
Easiest way to find out if its the fuse, is to look at the fuses with a flashlight and see if any of the links are broken. If there are any blown you'll see and you should replace the ones blown. That should tell you which one is connected to the CIG lighter. If you don't find any are blown then your CIG lighter connections behind the actual CIG lighter might be loose.
Mar 23, 2015 | GMC Cars & Trucks
Fuse of stop light runner 93
If you are thinking you have a blown fuse, this will help you find it in seconds. Remove each fuse 1 by 1 and immediatly replace it with same one if its good so you won't mix them all up. Keep going 1 by 1 and and put them each back untill you find the blown fuse. If you don't find any that are blown, then you have another problem. If you don't know what a blown fuse looks like, here is a picture so you can tell the difference.
Dec 07, 2013 | Cars & Trucks
How can i tell if a car fuse is blown
Visually look in the fuse and see if there are any burnt ends in the middle wire. If you have a ohm meter set to check continuity. The easiest way if you don't have tools is to switch the fuse with another of the same amperage.
Oct 25, 2013 | 2004 GMC Envoy
Maytag Neptune Model #MDE5500ATW How to tell if the thermal fuse is blown
If this THERMAL fuse is blown it would not operate at all. If it runs but don't heat it probably is a limit or the heater. If you see a lot of junk in the vent pipe AND it still runs then the heater limits are gone. If the vent it clear but filter housing or blower has an issue then it won't run and the thermal fuse is gone bye bye.
SERVICE MANUAL for slopefaced dryer
Sep 03, 2012 | Dryers
How can i tell if my amp is blown
check your amps fuses if they are blown thats your problem also check the fuse underneath the hood from the cable going to the amp if that fuse is blown fix it. that will turn ur amp back on. also if your blue remote wire is loose it will not tell the amp to turn on. thats how u can tell. if all fuses are intack. and blue wire is then its blown
Mar 19, 2011 | Car Audio & Video
My 12v charger is not working, which fuse would be the problem, looked at old fuse box diagram which lists that the horn and charger use the same fuse the horn works. Focus 2008 Titanium?
5c1d682.jpg above is a picture of a blown fuse...if the fuse where not blown the at the top of the fuse are two metal progs....if us a multimeter of a fuse tester it will tell you without removing the fuse if it is blown....the fuse testers are at any auto store and usually pretty cheap.....good thing to have...saves lots of time. I would use this method over a diagram in a car because someone could have rerouted power in your case to another fuse...or worse...to no fuse at all. Any way this will help you find any blown fuse and quick
Nov 02, 2009 | 2008 Ford Focus
RCA F19430 19" TV Logo
16 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
