Question about LG LRTBC1825T Top Freezer Refrigerator
HOW DO I SOLVE THE PROBLEM OF LEAKING GAS IN MY REFRIDGERATOR?
  • 400 Answers
Much would depend on where the gas is leaking. If it is visual it would be simply a matter of welding up the leak and recharging. However if it is internal, there is very little chance of successful repair. If it is still quite new you may find that it is still covered under warranty by LG
Posted on Mar 11, 2009
Samsung rf267 series refridgerator not cold enougheverything else works fine its just that the milk goes off and things go bad because it doesn't get cold enough
this could be your stat has gone or you have an insulation leak gas leak you will need a fridge engineer believe me it will save you loads a call out should cost you around 25 to 30 but its cheaper then any thing else ok
Oct 22, 2012 | Refrigerators
How do I recharge a magic chef mcbr440b refridgerator
You need an access valve, manifold guages, leak detector and refrigerant. If you are having to ask how, you are almost certainly not going to be able to do it. It needs leak checking first, leak repairing, vacuuming, new drier, new gas charge. Call a technician or get a new fridge
May 16, 2012 | Refrigerators
Refridgerator and Freezer sections not cooling
Check power is o.k. And then check power to relay. If o.k., Check compressor is working. If not replace relay. After replacing relay compressor working. Keep your arms on discharge pipe line. If warm, gas is o.k. Otherwise, gas leak. If warm and whistling sound inside the freezer, gas flow is normal. If not, system chocked. Release gas and flush out system, vacuum and gas charging.
Hope, helpful.
Jan 26, 2011 | Baumatic Refrigerators
The freezer colds like the bottom of the fridge and the bottom of the fridge is hot
Sounds like a refridgerant gas leak, if not to old it may be worth getting the leak fixed and regassing the unit but its a job for a professional.
Oct 25, 2010 | Samsung Refrigerators
My Sanyo refrigerator (model SR-4431S) isn't cooling like before and certainly will not make ice... While scraping ice from the freezer compartment up top, I accidentally made a small puncture in the back...
Hi!
Before you can refill the system, you need to have the leak fixed. They have to evacuate the system, weld shut the leak, vacuum the system for 30 min. and refill refrigerant to proper level. This is a job that by Federal Law has to be performed by an HVAC Certified Technician. Take the unit to an appliance repair shop for repair, this way you'll save on the service call.
A HELPFUL - 4 THUMBS - Rating and a TESTIMONIAL would be greatly appreciated if you are satisfied with this FREE solution. Thank you for using FixYa.
Oct 22, 2010 | Sanyo SR-4310 Compact Refrigerator
I own a Cadillac Seville STS, on my dash it reads refridgerant very low , and also it says A.C compresser off. I just refilled my coolant with refridgerant with the r142a and it did not work.The dash still...
You have a leak in the ac system, u will have to have the system leak tested and the leak repaired before adding anymore very expensive R134 refridgerent.
Jul 02, 2009 | Cadillac STS Cars & Trucks
Leaking water
turn the water off its behind the unit on the wall .
you might have a busted pip in the door but only tech' can fix that ....
Aug 30, 2008 | Kenmore 53082 / 53084 Side by Side...
Refridgerator
YES THIS ISSUE THAT YOU HAVE MOST PEOPLE DO NOT BELIEVE EXISTS BUT IT DOES AS YOU KNOW
The solve for the solution is to spray paint all of the copper tubing at the compressor connections , and any of the tubing that you can even if it means laying the machine down on its back to get to them black enemel spray paint will work you choose gloss or satin. it keeps the sulfur gas from attacking the copper
btw take a look at other items in the house that have copper in them light fixtures light swithes recepticals, air conditioning coils
bet that they are tarnished
Apr 17, 2008 | Refrigerators
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
LG LRTBC1825T Top Freezer Refrigerator Logo
219 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
