Question about Maytag MVWX500XW HE Washer
Mvwx500xw doesn't spin out all water
When washing heacy loads, defaults to low spin and will not spin out all water, Requires manual setting to drain and rinse additional cycle. Maching is approx. 3 years old and just recently began doing this.
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
  • 1738 Answers
SOURCE: My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Posted on Nov 20, 2009
Testimonial: "Thank you very much. I found out I need special tool to remove the water pump's screws. It is not diffcult do it with diagrams. "
  • 239 Answers
SOURCE: washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Posted on Apr 24, 2010
TheMobilian
  • 8220 Answers
SOURCE: Have a Maytag washer LAT9635AAE. It fills with
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
Posted on May 18, 2011
Testimonial: "TheMobilian, you're the best. Decided to repair instead of replace per your advice, and your solution was perfection. Back in service thanks to you!"
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
My new Maytag Bravos HE top load MVWX500XW vibrates during spin, is this normal?
from the way you describe the issue it sounds normal, all washers vibrate at least a little or alot (depending on the balance or unbalance of the load) if it is just vibrating and not making a grinding or scraping noise it is fine, if its vibrating too much for your like, try to rebalance your load.
Oct 03, 2012 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Water does not drain
see this causes:
It spins, but doesn't pump
drain line clogged, ome sock in the outer tub, use pliers for large hose and pull out,test the pump can be faulty.
It doesn't spin or pump
frozen pulley pump, replace, move manually see the diagram, if not replace
It pumps, but the water returns
improve the drain line, if the drain hose reach the 4 inch cut of the excess, if is lower, install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Kenmore Elite 45986 Front Load Washer
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Water doesn't drain
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
Maytag MVWX500XW HE Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
