Question about Yard Machines Garden
Is there a switch in the rear end of a yard machine garden tractor to make it faster
Have an older yard machine automatic transmission that at hight idle and full speed only does about 3 to 5 mph and was wondering if there was a switch somewhere to to make it faster
    Guru:
  • 145 Answers
NOPE
Posted on Apr 13, 2014
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
  • 32 Answers
SOURCE: Hi, Ineed 5 speed Peerless transmisson for a troy
if you are handy you can take it a part and replace the parts inside. or drive around the country and find a mower with no engine for cheap. go to the Tecumseh web site to see witch trans are the same most bolt up
Posted on Jul 23, 2009
rycgl
  • 1545 Answers
SOURCE: I began mowing my lawn, with my riding garden
Check your linkage connected to your transmission gear shift lever.
Posted on Jun 16, 2010
  • 111 Answers
SOURCE: my yard machine 6.75 is idling a little low; how
There is a spring by the air filter box on the front of the engine (spark plug side of engine). It is a little behind the air filter box. Using your index finger you will be able to pull it towards you. I would not move it very much. This will increase the rpms. To lower the rpms push it back a little. You may have to do this a couple of times to get the rpms just right. Hope this helps.
Posted on Apr 03, 2011
SOURCE: 1995 AGS 2140 clutch or transmission problem when
i have an AGS AJ102 I need to find a user manual please can you help?
Posted on Apr 11, 2011
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
1999 statesman lawn tractor with automatic transmission the shifter wont go all the way forward to make it go faster
Do a complete maintenance chec. With machine that old u hav lube issues, fluid etc. Library has shopbooks for troublshootn
Jun 01, 2015 | Garden
I have a 650 Yard Machine by Briggs and Stratton and I lose transmission power when going up hills. Is there a reservoir or something to adjust to gain transmission power back?
no but you might check two things... the engagement cable and the belt. if both of those appear ok... get use to pushing it uphills
Oct 18, 2014 | Yard Machines Garden
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
Can I add fluid to rear tires w/o hurting rear end.
Adding fluid to the tires should not affect the transmission at all.
May 19, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
How to get rear wheel off yard macine rider
LEAVE MOWER IN GEAR(NOT RUNNING OF COURSE),PUT REAR END UP ON BLOCKS,REMOVE THE CAP,USE BREAKER BAR SET SOCKET ON NUT WITH HANDLE FACING FRONT SUDDEN **** SHOULD MAKE IT BREAK FREE.
May 02, 2009 | Mtd Garden
Garden Logo
44 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
