Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
How do i fit forward lock on dyson dc07 - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
chrispurs1
  • 372 Answers
SOURCE: problem fitting new motor into dyson dc07 casing
Hi.
There is try this site http://dysonmanuals.inc.io/
Posted on Nov 15, 2007
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
Posted on Jun 29, 2008
SOURCE: DYSON MOTOR BRUSHES
how do I change the carbon brushes in a dc07, I have removed the brush units from the motor
Posted on Jan 18, 2009
Samyfam
  • 379 Answers
SOURCE: Dyson dc07 suddenly lost all power. Bad power
This could be the switch, but could also be the motor.
The motor has a built in over-current protection device which normally automatically resets itself, but if the motor has had it, it then just cuts out again as soon as you switch it on.
Both the switch and motor are available quite cheaply on eBay, but fitting new ones requires good DIY skills (especially the motor), and some unusual tools (Torx drivers).
Have a look at www.dysonmedic.com which has some great info on repairing your machine, but if you dont feel you can repair it yourself, time to call a vacuum repairer or the Dyson helpline.
Posted on Feb 28, 2010
Samyfam
  • 379 Answers
SOURCE: replace brush bar on dyson dc07
Replacing the brush bar on a DC07 is quite straight forward and how to do it should be shown in the user manual.
If you dont have the manual, or if it isnt covered, have a look at www.dysonmedic.com which has some great info on your machine.
Posted on Mar 06, 2010
Where is the brush belt on a dyson 07 upright vacuum?
Hi there, it's Jack at Dyson.
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Are attachments interchangeable between dc33 and dc07 or dc14
Hi Stephanie, it's Jack at Dyson.
The Dyson DC33 vacuum cleaner has a click-fit connection design which allows tools to lock in place securely during use, until you remove them using the silver catch on the wand handle.
As the tools for DC07 and DC14 use a push-fit connection design, they will not be compatible with DC33. However DC33 does come with its own set of tools including the Stair tool and the Combination tool.
I hope this answers your question, but if there's anything else we can help you with you can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA), or 1800 239 766 (AU).
Jan 18, 2014 | Dyson Vacuums
Dyson dc07 is making weird noise
I'm sorry to hear your DC07 is making a popping noise in use. Unusual noises can be caused by a number of different issues, and in order to determine exactly what's causing this we would need to hear it. I'd encourage you to call our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our experts will be able to listen to the machine over the phone and diagnose the cause of the issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The cyclone is loose on the main body when i grab the handle it just comes off
Hi Alan,
I'm sorry to hear about that. In order to determine why the cyclone is not fitting securely on your DC07, we'd need to run through some troubleshooting checks over the phone with you when you have the machine to hand.
You can reach us on 1-866-693-9766 (US), or 0800 298 0298 (UK).
Best wishes,
Jack
Jun 12, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi im trying to change one of the belts the one that goes round the brushes but cant seem to see how to fit it on
The belts in the clutch system fitted to DC07 Allergy can only be serviced by an engineer. If you're concerned that the brushbar doesn't seem to be working as normal, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 22, 2011 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Can i replace upright locking mechanism dc07 vac works fine but have to make sure it is pushed upright to use pipe will not lock looks like button is stuck in
Sorry to hear you're having difficulties with your DC07. If the cleaner won't lock in position when you stand it upright, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Jul 10, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just bought a refurbished dyson dco7. It is making a loud whistling sound after I have been vacuuming for a few minutes.
Sorry to hear you're having difficulties with your DC07. A whistling sound could be caused by a seal which is missing, damaged, or incorrectly fitted. It's probably best if you get in touch with us directly - one of our experts will be able to determine the cause of the whistle over the phone, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Jun 11, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace brush bar on dyson dc07
Mar 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
