Question about Acer Aspire 5100 Notebook
I ahave an aspire 3680 laptop. The dial up modem cannot be found. When I go to Control Panel and the Phone and Modem option, no modem is listed. The Hard Drive was just erased and formatted by my son.
  • 170 Answers
You can download the drivers for your system here:
http://www.acersupport.com/notebook/index.html
Hope this helps,
David
Posted on Mar 11, 2009
I want to use my blackberry 8520 as modem to my laptop
Yes. I used to do that before 3G became popular.
The Dial Code depends on the country and carrier. I used *666#
Set Up a Dial-up Connection
You'll need to set up a dial-up connection on your Windows machine to use the BlackBerry modem. When you installed the BlackBerry Desktop Manager, it should have automatically installed the modem drivers to use with your device, and you should have a modem called "Standard Modem" in the Phone andModem Options section of your Control Panel. The drivers are located in the following folder: C:\Program Files\Common Files\Research In Motion\Modem Drivers. Use the following steps to set up your connection:
  1. Connect your BlackBerry to your computer using the standard USB cable that came with your device and start the BlackBerry Desktop Manager software.
  2. Go to the Control Panel, then Network Connections, and select Create a New Connection.
  3. Select Connect to the Internet, then Set up my connection manually, then Connect using a dial-up modem, and select your BlackBerry modem from the device list.
  4. Choose a descriptive name for the ISP Name (e.g., BlackBerry Modem Connection).
  5. Enter the phone number for your service provider. You'll probably have to check with your carrier to get the right number. For Cingular and other GSM carriers (AT&T, T-Mobile), it's *99#. For CDMA providers (Sprint, Verizon), the number will be #777.
  6. The username and password will vary by carrier as well. Cingular just accepts null values for both fields.
  7. Complete the wizard, being sure to deselect the "Make this the default connection" checkbox.
How to use Blackberry Curve phone as modem O2 Guru TV
Jul 16, 2016 | RIM BlackBerry Curve 8520 Smartphone
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
Does my new Emachine laptop have no dial up modem?
Correct. It's looking for a standard dialer modem. You may just need to go through the internet connection wizard and define how you want to connect. With a wireless adapter, you could locate and connect to internet with that instead of a dial-up modem. Internet connetion wizard comes with Vista and XP and is found: Start > Control Panel > Network connections.
Oct 19, 2009 | Computers & Internet
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
My acer laptop is not getting a dial tone but the phone line is good. If the modem is bad, where is it located on the laptop?
Hello flubber20054,
The modem settings can be accessed through the windows control panel as follows:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select Phone and Modem Options (Brings up the phone and modems properties sheet)
•Click on the 'Modems' tab
•Highlight the modem's name
•Click the properties button
•Look for the words 'Device Status' on that page.
If the message box says 'This device is working properly' then the modem is working ok. The Phone and Modem Options also has a tab called 'Dialing Rules'. The dial tone might work if you 'Edit' the existing Dialing Rule or Create a 'New' Rule. When you 'Edit' or create a 'New' rule, enter the requested information as best you can. You can always go back and 'Edit' the rule to keep testing it. I hope this gives you some ideas for resolving the dial tone problem.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 04, 2009 | Acer Aspire 5720-6661 Notebook PC
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Acer 3680 agee modem
Goto support.acer.com then select your laptop then country next drivers. Select device and download.
Regards B.
Mar 21, 2009 | Acer Aspire 3680 Laptop
Modem
go to the acer website and then to laptops choose your laptop i guess its a aspire 3680 download the sound drivers and install it then download the modem and install it manually, i think there are 2 of them there try both one will work out.
good luck. rate me
Nov 11, 2008 | Acer Aspire 3680 Laptop
I Can not install modem what i should do know
To install a modem
1.
Open Phone and Modem Options in Control Panel.
2.
(Optional) If you are prompted for location information, enter dialing information for your location and click OK.
3.
On the Modems tab, click Add.
4.
Follow the instructions in the Install New Modem wizard.
To open Phone and Modem Options, click Start, click Control Panel, and then click Network and Internet Connections. Under See Also(or Hardware and Sound), click Phone and Modem Options
Goodluck,
Do not forget to rate me as Fixya..
Nov 28, 2007 | Toshiba Satellite A135 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
