Question about Acer Aspire 4720 Notebook
I cant instal xp. itsay hard disk not detect when boot
  • 127 Answers
Go to the BIOS setup, & change the disk controller setting from AHCI to IDE. might worth the try.
Posted on Mar 15, 2009
Sata drivers pt80c-alx boot
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
May 01, 2012 | HP Computers & Internet
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Aug 12, 2011 | HP Compaq 6720s Notebook
Can not installing windows xp & cant detecting the sata hard drive how can i installed the sata drivers
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive, this will make XP think it is a IDE/PATA hard disk.Then install XP normally. After Windows XP is installed then install all the device drivers (including the SATAdriver), then shut down and boot up and got into the BIOS and enable the SATAdrive.
Dec 15, 2010 | ASUS P5RD1-VM Motherboard
Hi.I want to format my hard disk and install windows xp home edition. But it end up by saying it cant detect my hard disk. im using MSI km400 with sata.
Windows XP comes in 2 'flavors', one being the OEM or 'Full' version, and the other is the 'upgrade' version. The Full version will setup and format the hard disk, applying the boot track. The Upgrade version expects to see the boot track there, and will not proceed further. You may need a utility like Seagate Diskwizard to setup the hard drive for installation. That program can be downloaded from Seagate's website.
Apr 02, 2010 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
No system found ...and tells check cable
Can you enter the CMOS and veryfy that is boothing from the hard disk? you have to remove any cd, dvd, usb drive too. Enter the BIOS/CMOS by pressing F2 xor DEL when booting. Look for BOOT sequence, and set the hard disk as firt boot device. If after that doesnt boot, reinstall OS and if after that doesnt boot, you need a new HD.
Aug 11, 2009 | Acer Aspire 5050-3242 Notebook
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Acer Aspire 4720 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
