Question about Kirby G10d Vacuum Cleaners
I have a kirby G10D after replacing fan it will not turn easily
When turne on makes a noise and alto motor turns easily when off doesn't seem to be working right when on
  • Kirby Expert
  • 324 Answers
If you mean that you can't turn the shaft by hand then you probably have removed motor to replace the fan. When installing it back you should have tightened screws on the bottom of the unit first and then ones that are inside (with large washers). If this is not the case then we would need more info on what exactly you mean by "not turning easily".
Posted on Dec 19, 2013
SOURCE: Vibrating and noisy Kirby
Power off the vacuum.
Unplug the power cord from the wall.
Remove the head or hose attachment.
Look at the fan and make sure all the fins on the fan are there.
If part of one or more is missing it will cause the fan to wobble and shake.
Posted on Oct 19, 2007
b0sslady2001
  • 357 Answers
SOURCE: Loud Noise
I believe you will find the answer you seek by clicking on this link.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope it helps...
Marci
Posted on Feb 06, 2008
  • 120 Answers
SOURCE: KIRBY ISSUES! :(
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
Posted on Sep 26, 2008
VacuumRepair
  • 438 Answers
SOURCE: My Kirby Ultimate G is
Greetings from GoVacuum,
The Kirby vacuum is a very well engineered vacuum cleaner. There's usually not many things that go wrong with them.
You may just need to replace the belt on the machine, this should take care of the not picking up part. Even though the belt may not be broken, it may have stretched to a point where the roller brush is not spinning as fast as it should. This will effect the vacuum's performance, and make it not pick up as well.
Here's a video that we did showing how to replace a belt on Kirby vacuums. If this doesn't take care of the problem, let me know I'd be happy to try and help you determine what the problem is. One other thing you may want to look at, is the fan on the machine. When you take the front agitator housing off of the machine, look inside the vacuum at the fan, make sure that there are no cracks, and that the fan is not broken off.
Posted on Oct 03, 2008
  • 41 Answers
SOURCE: Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Posted on Aug 05, 2009
Kirby G10D not driving on assist. every thing looks good when in gear turning the wheels the transmition does not turn Why?
First thing to check is if when pushing pedal it moves gears located on the rear Kirby transmission axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken. If it is then just replace entire set to make sure that belt type matches gears and the set is not that expensive
Last and the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission ) Kirby Transmission Troubleshooting
800-775-6586
GoodVac com
Feb 22, 2015 | Kirby Vacuums
Kirby g10d, I shampooded the carpet then put it back together and it wont start 4/12 yrs old used approximately 50 times. Any ideas?
Make sure the emptor at the. Bottom of the bag assembly is turned all the way clockwise. It pushes in on lever on the switch. It won't run if the lever is not pushed all the way.
Jan 31, 2015 | Kirby G10 Sentria Vacuum Cleaner...
My green light went out it dont suck up
is making a big noise as lifters noise i openned it and is nathing there, I was waching on youtube that can be the steering wheel
Aug 30, 2013 | Kirby G10D Vacuum
HOW TO PUT BELT ON
this is a video how to replace the delt on kirby
Jan 07, 2013 | Kirby G10D Vacuum
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
Nov 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
Motor problem
First six pictures HERE will let you know how to remove shell to see the motor. I would not recommend starting it before you get the screw out (you will need to remove 5 more screws from the front f the unit to get the fan case off). The fan case is glued so you may need to use screw driver and pray the fan case of the unit. If fan is damaged - remove it from Kirby as damaged fan is out of balance and Kirby will vibrate like crazy. Shaft has opposite thread so you have to turn it CLOCKWISE.
If the fan does not come off easily you may have to remove this part and access the rear of the motor where you can use a wrench to hold the armature (you will see where you can hold it right behind the commutator. Removing slide bracket assembly memorize where the wires are plugged in and how it is engaged with the transmission.
God Luck
Rocky
Nov 10, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Sentria
sounds like the motor burned up. not sure if travel adapters will handle a large load like a motor, around 8 or amps. power needs in US are 110 volts ac, 60 hertz.
I believe UK is 220 volts and 50 hertz.
usually when a vac is brought to europe you must change motor.
Jun 13, 2008 | Kirby Vacuums
Oct 18, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G10d Vacuum Cleaners Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
