Question about HP Photosmart D5460 InkJet Printer
HP Photosmart d5460 Printer "Ink System Failure 0xc19a0040
    New Friend:
All of these do not work. HP is a crap printer. do not buy
Posted on Apr 30, 2015
SOURCE: oxc18a0201 ink system failure. Apparently
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
Posted on May 28, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
MUKHTAR
  • 2022 Answers
SOURCE: HP Photosmart C6180 Ink System Failure Message
just follow this steps may help you out otherwise you need to change it.
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues,then you can go for repair or buy a new one .but i advise you to dont go for repairing bcoz it is 3 year old .
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
pineworks
  • 4041 Answers
SOURCE: Ink system failure HP PhotosmartD7160
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: HP Photosmart C6280 printer won't print and
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Posted on Feb 10, 2010
How to check Ink Levels on HP D5460 Printer
You can check your ink levels through your PC/Laptop. First make sure you have the proper driver installed based on your computer's operation system. Go to the following link to install the driver specified for your computer's operating system: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3396080
If your driver is properly installed, then go to:http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457163&tmp_track_link=ot_recdoc/c01463998/en_us/c01457163/loc:1&lc=en&dlc=en&cc=us&lang=en&product=3396080
Dec 19, 2011 | HP Photosmart D5460 InkJet Printer
Hello, I have a HP Photosmart D5460 Printer and all I did was change the printer cartridge and now I cannot get the printer to print can you please help
This particular issue, i.e. 'ink system failure' with the error code starting with 0xc19a for teh Photosmart C6300, D5400 and D7500 is being handled by the Level 2 techs at HP and all L1 agents have been instructed to transfer the call to the L2 techs. So give a call to HP Tech Support and they will take care of this one way or the other.
Jun 03, 2011 | HP Office Equipment & Supplies
Ink System Failure 0xc19a0036 tried unplug printer replug printer....cleaned print heads....still not printing. Help!
You could try to reset your printer.
Press the power button to turn on the printer.
With the printer on, disconnect the power cord from the back of the printer.
Wait at least 20 seconds.
The printer should turn on, if not, press power button.
Dec 28, 2010 | HP Photosmart D5460 InkJet Printer
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
Ink failer
Applicable error codes
This document applies to Ink System Failure error messages with any of the following codes:
0xC19A0001, 0xC19A0002, 0xC19A0003, 0xC19A0006, 0xC19A0008, 0xC19A0009, 0xC19A0013, 0xC19A0014, 0xC19A0015, 0xC19A0020, 0xC19A0021, 0xC19A0022, 0xC19A0023, 0xC19A0024, 0xC19A0025, 0xC19A0026, 0xC19A0027, 0xC19A0028, 0xC19A0030, 0xC19A0033, 0xC19A0034, 0xC19A0035, 0xC19A0036, 0xC19A0037, 0xc19A0040, 0xc19A0041, 0xc19A0042, 0xC19AC001, 0xC19AC002, 0xC19AC004, 0xC19AC008, 0xC19AC010, 0xC19AC020, 0xC19AC040, 0xC19AC063, 0xC19AC080, 0xC19AC0a5, 0xC19AC0c6, 0xC19AC0e7, 0xC19AC100, 0xC19AC129, 0xC19AC14a, 0xC19AC16b, 0xC19AC18c, 0xC19AC1ad, 0xC19AC1ce, 0xC19AC1ef, 0xC19AC200, 0xC19AC231, 0xC19AC252, 0xC19AC273, 0xC19AC294, 0xC19AC2b5, 0xC19AC2d6, 0xC19AC2f7, 0xC19AC318, 0xC19AC339, 0xC19AC35a, 0xC19AC37b, 0xC19AC39c, 0xC19AC3bd, 0xC19AC3de, 0xC19AC3ff, 0xC19AC400
HP Photosmart C6380 and others
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Feb 21, 2010 | HP Photosmart C6280 Printer
Getting no printer installed message with windows vista
First check that your HP Photosmart D5460 shows up in control panel. If not, perhaps it is not installed properly.
If so, check that your HP Photosmart D5460 is the default printer. Right click the printer name and choose "Set as default printer" option.
Dec 20, 2009 | HP Photosmart D5460 InkJet Printer
Can't turn my HP D5460 off
To turn off the HP D5460 Photosmart is by pressing the ON button located on the product. Wait until the on light turns off that mean it's off.
Apr 12, 2009 | HP Photosmart D5460 InkJet Printer
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D5460 InkJet Printer Logo
846 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
