Question about Avanti D110 Electric Portable Dryer
I can't locate my lint filter
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
My TDP-P75 toshiba projector keeps cutting out for no reason - any advice anyone?
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Dec 08, 2012 | Toshiba TDP-S8 Multimedia Projector
Does a Amana commercial quality washer (model LWA50AW) have a lint trap?
You will need to remove the agitator and inner basket to access and replace the lint filter. It is best to replace the filter and not to try and clean it.
Here is a link to the filter.
Oct 13, 2012 | Amana NAV6800AW Top Load Washer
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
Location of fuses for cabrio dryer # wed6200swl
pull out the dryer,remove the vent line and remove the back wall,you'll see the metal duct that the lint filter slides down into,look to the bottom right of the duct,you'll see a white piece with two wires on it,this is the thermal fuse part number 3392519,fuses are usually on the blower wheel housing and on the heater housing,if the lint filter is on top then the fuses are in the back of dryer,if the lint filter is inside then the fuses are up front.if the fuse is bad you have to clean out the dryer and blow out the vent line,remove the duct that the lint filter slides into,your filter is on top so remove the two screws that are in front of the lint filter onthe top panel,then if the vent line is long you can blow it out with a leaf blower,first go outside and make sure there isn't any covers or anything blocking the vent,if there is a cover remove it,the lint will keep getting stuck in it and you'll have problems.so check the thermal fuse and if that's good check the thermostats and high limit on the heater box,also make sure you have 240 volts going to the dryer,check the door switch,also make sure the belt isn't broke,there's a switch that kills the power if the belt is broke.hope this helps if not you could have a computer board issue
Sep 07, 2012 | Whirlpool WED6200S Electric Dryer
When I drive along it's all fine, but when I put my foot down the car starts to skip like its short of fuel.
Do not do anything if it is a common rail diesel without more instruction. Common rail can be very dangerous & the following instructions are not for common rail. Probably is short of fuel. When was the fuel filter last replaced & the sediment trap drained. A lot of diesels also have a lint filter (fine mesh) located in the pump where the fuel line goes out of the filter into the pump. You just remove & blow out with compressed air. Do you know how to prime & bleed the system. Did the problem start just after haveing a fuel filter fitted?
Jul 01, 2012 | Nissan Navara Cars & Trucks
Has anyone had problems with lint building up inside samsung DV330AE dryers
talk with a service agent , but by design the only way lint can get out of the unit is from a badly fitted lint filter
the air is blown into the dryer tub and exits through the filter to the vents
there may be a recall on the units so calling and talking will get an exact answer
Mar 23, 2017 | Samsung DV330AE Dryer
Theres a problem with the drier as dof theres never any water in the tray anymore , and the drier is filling with fluff, takes ages too dry anything , what do you recommend plerase angela
Check your exhaust line and lint filter. Go outside and locate on the wall where the dryer exits the house. If you can, feel around the inside and clear the exhaust of any lint or debris. Next, check the lint filter. If it's packed, remove all lint from it and clean with mild soap and water. Put the filter back in it's place. Turn on dryer's normal setting that you most commmonly use and star dryer. Go back outside to where the dryer vent exits the house. Place your hand over the vent. You should feel hot air coming out at a pretty decent rate.
Jul 09, 2011 | Hotpoint Dryers
Dryer "clean lint filter" message
Hello. Begin by unplugging the plug on the dryer. Then pull out the filter and thoroughly examine the space that the filter slides into looking for any lint. Remove any lint that you find. Put the filter back and lastly plug the dryer back in.
These steps should solve the problem. If not, then the lint sensor has gone bad and should be replaced. If you wish to do that yourself you can go to searspartsdirect.com. Enter the model number of the dryer and then you will see the parts diagrams allowing you to locate that lint sensor, and even order a new one. Joe
Thanks for choosing Fixya!
Mar 07, 2011 | Dryers
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Avanti D110 Electric Portable Dryer Logo
26 people viewed this question
Top Avanti Dryers Experts
Tim Whalen
myrlanthian
Are you an Avanti Dryer Expert? Answer questions, earn points and help others
