Question about RCA L26HD31 26 in. LCD HDTV
RCA L26HD31 takes 30 plus minutes to come on
Unusal long start up tiome
3 Suggested Answers
  • 46 Answers
SOURCE: Cannot connect my pc via hdmi to an RCA L26HD31.
If your trying to use a computer with a video card that is not HDCP capable it will not work.You'll need to replace the video card that has hdcp .You can thank Hollywood for that.Hope that helps
Posted on Apr 27, 2011
mobil master
  • 14641 Answers
SOURCE: rca l26hd31 no sound no picture
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
Posted on Nov 03, 2012
My RCA 61960 projection screen comes on and works for a day or two fine, then loses picture and displays "unusable signal".
Pull the back and look for bulged capacitors, that may not be the issue but its a good place to start.
Nov 14, 2017 | RCA Televison & Video
Rca l26hd31 no sound no picture
Nov 02, 2012 | RCA L26HD31 26 in. LCD HDTV
Cannot connect my pc via hdmi to an RCA L26HD31. TV registers unusable signal. Is the set bad, or did this model not support hdmi from a pc?
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
This RCA L26HD31 TV has always worked fine in other respects... but when I try to connect my pc's hdmi cable to it for use as a monitor, I just get "unusable signal". When this TV was made, hdmi...
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Screen is hideous colors until it warms up oven a period of at least 45 minutes. Seems to work okay after that for quite some time.
The LCD panel digital control board is failing. The only way to replace it is to replace the LCD panel because it comes as one unit together. Most likely it will cost more to repair it than to replace it.
I am sorry for the bad news.
Skyassoc
Dec 10, 2010 | RCA L26HD31 26 in. LCD HDTV
Have sound but no picture
inverter board has failed try shop jimmys on the web
Sep 16, 2009 | RCA L26HD31 26 in. LCD HDTV
I can not connect my rca dlp HDTV to my hp laptop. I tried using VGA wire, laptop is fine but TV is showing unuseable signal
A lot of TVs only accept limite PC resolutions. Try 1028x768 60hz this normally works.
The Error message doesn't mean the TV or PC is not working, only that the signal is not compatible. try all resolutions until something works.
Jun 23, 2009 | RCA L26HD31 26 in. LCD HDTV
RCA L26HD31 26 in. LCD HDTV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
