Good day, I bought a proline PN6633-W7S ALL IN ONE pc and I can't hear anything from the internal speakers. The mic also seems not to work. I have checked the volume levels and ensured the drivers
Windows 7 Ultimate
I can't hear people but people can hear me
It could be a speaker issue. Try using you phone on speaker phone, or ear buds with with built in MIC or blue tooth headset. If it works with these options then its an issue with the speaker. If it doesnt work even with other options then its a more serious issue
Apr 09, 2013 | ZTE Score
My party can't hear me
If your windows is 7 right click the small speaker down right corner and choose recording devices the set default the mic you use like if you use internal mic set it default and if you are using head set mic set it as default otherwise go to the video chatting program and choose the default mic from there.....good luck
Feb 03, 2013 | Sony VAIO Computers & Internet
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
Internal microphone
Usually the speakers on the laptop would act as a microphone- go into speaker properties, enable microphone and see it reacts. Bar that, you could go with the usb or bluetooth microphone route (I use the same headset for my phone as a microphone for my pc)
Sep 22, 2012 | Computers & Internet
Good day, I bought a proline PN6633-W7S ALL IN ONE pc, but now windows has disabled my wireless connecticity claiming that I must activate it by pressing special hot keys (E.g CTRL + ALT + F8) but i have...
you can also activate it by going to control panel / network adaptors, right clicking on your wireless connection and enable.
OR control panel / network and sharing centre / change adaptor settings depending on your version of windows
Aug 27, 2010 | Computers & Internet
Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
Dec 29, 2009 | Acer Aspire 5720 Notebook
I got a problem with my mic
Good day, sir/ma'am , there are several reasons why a mic does not work, let me give some. 1. its not activated, to check if it is activated, load the sound recorder program on windows. press record and shout on the mic, wave patterns can be seen on the recorder. 2. you may activate the mic and speaker if you cant hear the voices by. opening the volume control settings, options, properties, place a check on mic volume. there are other optons as well. 3. the mic is physically damage due to open wiring. get a new one. hope this may help. thanks
Jul 16, 2009 | Radio Communications
Cell phone silence
It seems the phone may have had water damage.seems like your ear piece and mic dont work, but the loudspeaker does. Give the seller bad feedback and contact paypal. If all else fails, we can definetley help you look at my profile and we can take it from there.
Jan 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Headphone not working on the headphone.
Try the headfones through a sterio or something just to see if the headfone itself is not faulty if it is take it back to the shop and get a replacement. Else the socket for the plugin is faulty.
Sep 22, 2007 | Everex StepNote VA4103M Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
