Question about Crock Pots & Slow Cookers
Can I cook without the inner pot? - Crock Pots & Slow Cookers
No, sorry, but the inner pot is essential in every slow cooker I've ever come across.
Posted on Apr 20, 2013
Where in Johannesburg/West Rand will I be able to buy the ceramic cooking pot (inner black pot0?
Hi Tanya, If you can't find a store in Johannesburg try Ebay OR Amazon, I hope this helped.............CHEERS..
Apr 25, 2016 | Crock Pots & Slow Cookers
I have never had a slow cooker in my life and found this one in a garage sale without the manual. How does it work?
Yes you can use any cheaper cuts of meat or chicken and yes less liquid is used in slow cookers. add hard veges n use green veges for end of cooking time. cook for 6 or 8 hrs on low. Yeilds ecellent results. Find slow cooker books for great meals n desserts. I use mine every week.
Apr 22, 2015 | Crock Pots & Slow Cookers
How do I program the crock pot to cook a certain amount of time at one temperature and then lower the temperature and continue cooking
Without the make & model we can't give any meaningful advice on this.
You should either go to the manufacturer's web site to search for the manual or google make, model and the word "manual" or "instructions"
Jan 06, 2015 | Crock Pots & Slow Cookers
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
An enamel cookware baking dish that I particulary like fell and cracked on the outside (red surface) and there is also a small chip in the inner area where the food is cooked. Is there anything I can do to...
the crack may get bigger with use and any repair would have to be with foor safe materials / you could only use it with a coking bag ( makes cleaning easy . but its probably time to replace it , mm
Jan 10, 2010 | Crock Pots & Slow Cookers
Defective part
To better address the problem with your nonstick pot... I need more information on the steps you have used to clean the pot and the extent of damage to the pot itself.
You indicated that the damage has occured between the pot and the inner surface of the cooker base? Is this a corrosive damage or a build up of material on the inner liner of the base?
Often times a build up of 'hard water' minerals accumulates on the inner surface due to condensation and occasional overflows from the foods being cooked. They can appear to be a type of fungus or mold.
Jan 04, 2009 | Crock Pots & Slow Cookers
Crock pot lost power
the crock holds heat even after being turned off...so your food was still cooking for the 30 min it was off!
Oct 27, 2008 | Rival 3755 5.5-Quart
Meat Loaf question
this is a tech support site not a cooking site please refer to answers.yahoo.com
May 14, 2008 | Rival 3060 6-Quart
Warm setting
Units such as the "Countdown" and "Recipe" Smart Pot™ slow cookers have a designated warm setting. Basic Smart Pot™ slow cookers have an automatic warm feature that activates a keep warm function when the cooking time expires. This type of warm feature will not activate without the set cooking time expiring first.
Feb 10, 2008 | Rival 38601 Smart Pot 6-Quart
Crock Pots & Slow Cookers Logo
46 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
