Question about Stanley Bostitch Sb-1850bn 18-gauge Brad Nailer
Driver stays out after firing - Stanley Bostitch Sb-1850bn 18-gauge Brad Nailer
You probably have a worn air seal. Or perhaps some pneumatic tool oil might do the trick. A few drops in the air outlet then bumb some nails into a piece of wood.
Posted on Apr 18, 2013
Fires first nail will not fire second nail
Ez test. With nails removed, and door open driver should be at top of cylinder. If driver is down replace piston oring. If driver is up, lightly strike nose of gun against softwood. The driver should stay at top. If driver drops with light tap replace piston oring. If driver stays at top dry fire the nailer against softwood. The driver should hit the softwood leaving a mark and return to top. If driver stays down or does not travel all the way up pull the cylinder and make sure checkband is installed. Checkband is oring or rubber band covering series of holes on lower part of cylinder. Good luck
Jun 21, 2015 | Stanley Bostitch Coil Framing Nailer
07 caliber 2 injectors stay on 2 stay off no ground pulse have everything else
Cell phone?
stay on = stuck? (injects full time?)
MPI, most MPI cars are PNP, Plus, neg. Plus fired.
that is all injectors on one side are 12v key on(power bus)
then the ECU fires each injector by a pulled ground (a transistor does that)
if the ground pulse is missing
then"
1: the injector coil open (burned open , infinity ohms)
2: or the ecu driver is dead.
use and ohm meter (resistance ) DMM and measure the coil on all
4 ,they will all read the same , many are 10ohms
0 ohms shorted, way different burned up, Infinity, burned totally up.
Oct 16, 2013 | Cars & Trucks
Fires when air is plug in,driver stays out.
Most likely problem is the firing valve (tva6), easy to replace and not expensive. Good time to remove the head and lube headvalve with white grease. For now be sure to remove the nails after use and install nails after air connected. Good luck
Jun 20, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
01 impala driver seat heater stays on with ignition off
Pull fuse or a fire will result if this stays on
Jan 05, 2013 | Cars & Trucks
I have a duo fast SureShot 764 nail gun that won't depressurize after a shot is fired and the driver stays stuck out?
are you putting lubricating oil in the gun? it sounds like its very dry inside . but only a few drops in to the gun at a time, per manufactures recomendations, and only use the approved oil for that gun
Oct 06, 2012 | Tools & Hardware - Others
Gun will not shoot nails completely;no matter what wood,thickness,etc.they drive all but 1/2"
May be due to broken tip. Easy to check. Remove nails and leave door open. With door open, lightly tap the nose of the gun against coiled rubber hose or soft wood. The driver should stay at top position. If driver falls to bottom of the cylinder, replace piston oring. Now press nose of the gun against old coiled up air hose or soft wood and squeeze and hold trigger. The gun will fire and the driver should stay in the down position untill you release the trigger (if not single fire trigger, if single fire trigger remove trigger and press the trigger pin with finger). While the driver is down, make sure that the tip extends past the nose about 1/4 inch (if air leaks past the nose in this position, replace lower bumper). If the driver does not extend past the nose, replace driver. Good luck
Jun 24, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
Nail gun will not fire a nail each time but only fires correctly ever other time and leaves dimple from the head firing.
Here are a few tests for you to try. You will need a piece of rubber or coiled up old hose.
First open side door and remove nails. Tilt gun head down then up again to check if piston is loose in the cylinder. The piston should stay in top position. If piston drops to bottom of cylinder remove head and replace piston oring or apply some layers of teflon tape under oring to expand oring slightly untill piston stays at top but still can be pushed down cylinder (look at the lower bumper to make sure that it is not cracked or missing pieces, if it is breaking up the pieces can lodge within the air path to the feeded piston). If driver piston now stays at top, connect air to gun and with side door open contact gun to rubber firing gun noticing the feeder movement. With very rapid firing of the gun, the feeder should move back and fourth just as fast as the driver moves. If the feeder seems to move slower than the driver moves then check/replace spring in feeder piston chamber. If spring seems strong enough in your opinion then problem is restriction in the air supply to feeder, if air path is clear then replace orings to feed piston. You will need to remove the two 6m allen screws at front of gun and split gun apart to check restriction at the oring sealing these two parts. Sometimes debris traped at oring (white oring) will restrict air to feeder. Good luck.
Jun 21, 2011 | Stanley Bostitch Nail Gun
My Stanley Bostitch SB-1850BN brad nailer will not sink the brad. It leaves it about an eighth of an inch above the surface. Adjusting the head using the adjustment thumbwheel does not help. Any...
You may have a broken tip or bent driver. Remove tha nails from gun and dry fire into a piece of wood. You should see a nice little indention. If you continue to hold the trigger and the nailer against wood after firing, the driver will stay in the lower position for examination. Just fire into wood and keep gun against wood while holding trigger and lean gun to side untill you see the tip. If you see broken tip or no tip order repair kit that includes driver, or driver alone from www.bostitch.com or ebay. Good luck
Sep 07, 2010 | Stanley Tools & Hardware - Others
Paslode framing nailer when fired pin stays out wont retract
Check the anvil guide for damage first (ie: burrs, nicks, etc.) Then go to the chamber for the return spring. That is where your problems are.
May 12, 2009 | Craftsman Nailer Kit, Palm Air Driver
Bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Nov 18, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch Sb-1850bn 18-gauge Brad Nailer Logo
56 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
