Question about Nakajima Office Equipment & Supplies
Some of the keys are dead or will work if pressed hard
  • Nakajima Master
  • 3,594 Answers
The keyboard needs disassembled and cleaned should be done by a person that knows the machine.
DickyO
Posted on May 12, 2009
Booting stops
Turn on the power and press F11 to run recovery without starting Windows. Then just follow the instructions. Just know that all files, pictures, and any other personal files will be erased permanently when you do this. Good Luck!
Feb 03, 2018 | HP Computers & Internet
Tip
LG E612 Hard Reset Google Lock
With article and troubleshooting guide solution for LG E612 Hard Reset Google Lock
  • Method (1): Backup PIN & Google Account.
  • On the pattern locked screen, click on the "forgot pattern" button .
  • You will be asked to enter Backup PIN & Gmail ID & password that was being used in the phone
  • Phone will be unlocked once you have provided Backup PIN ,Google account ID and correct password.
  • Note: No user data will be erased in while resetting pattern with above method
  • Method (2) : Pattern unlock with hard reset.
  • If you do not remember Backup PIN or the Gmail ID & Password details or you has not logged in with his Gmail ID then you should perform hard reset.
  • Note:This method will erase all user data and settings from the phone. and process is irreversible.
  • Make sure phone is Powered Off.
  • Press & Hold the "Volume Down Key (V-)" and "Power button" altogether
  • As LED at the bottom of the phone lights up, Release both pressed keys (V- and Power key)
  • Just after releasing the keys, press & hold "Home" key for about two seconds.
  • The phone will turn ON & perform Factory Reset immediately.
  • Warning!During working on this trick if accidentally your handset may have dead or faulted. We are not responsible for that please read our privacy policy.
Phonetolls
http://i.fixya.nethttp://i.fixya.nethttp://i.fixya.netwrite_tip-jtiacr1a5dvtxudcpg5eyczh-3-0.jpg
on Jun 24, 2015 | Cell Phones
2004 Toyota Matrix. One remote works, other does not and battery is good. Is there a reset or any programming necessary? Last owner never used this dead remote and it sat in a closet. Battery's...
programing a remote is not hard but it is timing is every thing!
set up. driver's door open all others closed.
all movements are done at one second intervals.
1 insert the key in the ignition and remove it twice
2 close and open the door twice.
3 insert and remove the key once
4 close and open the door twice.
5 insert the key
6 close door
7 rotate key to run back to off and remove.
(locks should cycle once)
8 press both the lock and unlock buttons for a second on the remote.
9 press the remote's lock button (locks should cycle once more)
Jan 04, 2013 | 2004 Toyota Matrix
My husband got a wicked virus on his computer and thought he cleaned it up completely. About 2 days later his hard drive died. In the BIOS it is listed as a HAWK hdd, but will not boot up in windows. Is...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hopefully then you can run your antivirus program to remove this virus
hope this helps
Dec 13, 2010 | Western Digital WD2500JS 250GB SATA2...
TI-84 Plus Silver Edt...unable to power up
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, try a hard reset. Remove one of the four AAA batteries. Press and hold the ON key. While holding down the ON key, replace the battery.
May 24, 2010 | Texas Instruments TI-84 Plus Calculator
Cannot detect hard drive when I turned on Dell
It's not dead or infected!! When the laptop turns on, press F2 this gets you into bios. Go to "Boot Sequence" If "Hard Drive" is listed there, then your hdd's dead! if not, go down until you highlight your hard drive. Mine says: HDD:C press space. it should now have a number next to it. Press "Space" on all the other numbers until your hard drive says: 1.HDD:C or whatever your harddrive says! press "Esc" and press save. now your hard drive should work. This might work for your laptop if your bios is "A011"
Nov 17, 2009 | Dell Inspiron 1525 Notebook
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
Dead calculator~!
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Nov 01, 2008 | Texas Instruments TI-83 Plus Calculator
37 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
