Question about Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer GEW9250PLO sensor stuck
The dryer is stuck in sensing mode
SOURCE: whirlpool dryer,duet
Problem: Push On Button, Press to Start. Click. Sensing. No Tumbling.
Solution: Called repairperson. Replaced Thermal Fuse (Part 3390719) and also suggested having venting system checked (ours vents through attic). Charged $198.00. This did not appear to be a problem that a layperson could fix, although a very handy person might be able to do it.
Posted on Feb 24, 2008
SOURCE: Whirlpool Duet dryer won't move past sensing function on any cycl
Found the culprit. The thermal fuse was blown. Had no conductivity with ohm meter so I placed a jumper around it and presto dryer runs. Cleaned the exhaust and fan but found no blockage and really was not that bad. Hoping maybe just a weak part. The model on the Whirlpool Duet electric dryer is GEW9250PWL I believe the the last three are just the color. The part number on the Thermal Fuse is #3392519. This is easy to get to through the front panel just below the load door. Hope this helps some else out.
Posted on Jan 22, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
SOURCE: Stuck on Sensing
Fixed! I opened up the top of the dryer (which can be done by simply removing three screws on the back of the unit and then sliding the top back and up) and found that the dryer belt was snapped in half. There is a belt tensioner near the motor that has a switch in it and will not allow the dryer to start if there is no tension on the belt. I was able to change the belt by myself for only $10, but it was not the easiest thing to do so calling a service shop would be recommended.
Posted on Apr 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: whirlpool duet dryer - when using the settings
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
Posted on May 22, 2010
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet dryer on sensing mode>what does that mean
The "Sensing Mode" occurs when the dryer is trying to detecting the dampness of the clothes in the dryer to determine if they are dry or not.
If the dryer is "stuck" in sensing mode - there is a problem that should be checked.
Sep 06, 2011 | Whirlpool Dryers
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front loading dryer Whirlpool Duet GEW9250PLO will not come on even after resetting.
check for electrical power if you have 220+ then check the door switch, jump the wirers if necessary. If switch ok, then move timer to 20 minutes and press start--if timer ok then you must have a broken wire in the wiring harness. Good luck.
Sep 04, 2008 | Whirlpool GEQ9800L Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
