I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem please can anyone help
  • 72 Answers
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Posted on Mar 11, 2009
How do i reset a desktop computer
Dell XP= Press Ctrl+F11 SimultaneouslyDell Vista=F8Compaq=F11HP Desktop Vista=F11Emachine=F10Acer=Alt+F10Remember every manufacture has different function key combination to to a factory default recovery.1.Turn on the computer.2.When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time. 3.In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.4.When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.When the restore process is complete, the following message will appear: The system recovery process was successful.5.Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
N.B F1/F8/F11(Function key Which is located in the top of your keyboard F1 to F12)
Mar 22, 2012 | HP Computers & Internet
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
Mar 18, 2012 | Toshiba Satellite L305D Notebook
I hv acer travel mate 5520 recently installed XP sp3 in my laptop then i found a prob when my laptop start an it came to window sign at start then my pc stop working or not start the window after 5 or 7...
go to run and type "msconfig"(without inverted commas)
go to startup tab and uncheck the softwares you don't require. this will certainly help.
Oct 31, 2009 | Computers & Internet
I need to get a copy of the recovery disc for the Gateway GM5048
Gateway sells the cds. If you tell them your model no they will send you a recovery disc (with a tiny fee of course).
Here's their number 866-539-3901
You can also live chat here http://www.gateway.com/about/contactus/index.php
Also, check this site out might turn out to be helpful.
http://support.gateway.com/s/software/MICROSOF/vista/7515418/7515418su539.shtml
Jul 25, 2009 | Gateway GM5048 (6304) PC Desktop
Need Recovery Discs
unfortunately most companys supply the recovery cds at a cost.
your other option, is to install an operating system ( Windows/Linux ) to get the system up and running, then check the device manager to see what device drivers need to be updated.
Mike @ compurepair.
Jun 11, 2009 | Computers & Internet
Sytem recovery not fully completed
Do you have the OEM Windows CD with Key Code numbers? If yes and there is nothing on the hard drive you want to save you could try a clean install. Go to set-up and make CD-ROM drive the first boot device and install a new OS. Sometimes with Windows this is the easiest thing to do. I see this recovery/restore stuff leaves a lot to be desired. In other words, it doesn't seem to work half the time.
Jan 06, 2009 | E-Machines eMachines Desktop PC
Windows error
First, make sure there are no discs in any of the drives as this could disrupt the boot process. Prior to seeing the HP screen you should get a prompt as to press F10 to go into system setup. Once in system setup choose the option to go to system restore or system recovery. From there you should be able to restore your computer to a sytem restore point that was set up with a checkpoint at set intervals by Windows XP. If that is unsuccessful you may have to utilize your recovery discs.
Good Luck.
Jun 27, 2008 | HP Computers & Internet
Systemax AOL Optimized
DOES YOUR HARDISK DRIVE DETECTED?IF NOT, TRY TO DISCONNECT IT FROM THE SYSTEM ,TURN OFF YOUR PC,POWER ON, PRESS F10 AND OPTIMIZE DEFAULT SETTING, SAVE IT.TYURN YOUR PC OFF CONNECT THE HARDISK,IF IT DETECTED, AND NO WINDOWS APPEAR,REFORMAT YOUR SYSTEM.
May 27, 2008 | Systemax AOL Optimized PC (100607) PC...
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Computers & Internet Logo
699 people viewed this question
David Payne
David Payne
