Question about Dell Latitude D630 Notebook
My dell latitude d630 I have pressed and held down the "FN" key and powered the laptop on. Firstly, all three status lights on ones and then stay off. What does this error light sequence mean?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
The thing i LOVE about Dell is their completely transparent with their systems.
http://www.solano.edu/technology/data/D630/trouble.htm#wp1311135
Posted on Apr 18, 2013
3 Suggested Answers
2coolrick
  • 560 Answers
SOURCE: dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
Posted on May 13, 2010
Testimonial: "Excellent purchased the new adapter and and what do you know problem solved.Thanks a million."
bob_computer
  • 3153 Answers
SOURCE: Dell D620 power light comes on when pushed but goes out 5 sec lat
There are two common causes for this and both relate to the power supply.
First is that the connector on the main board is loose or has a bad connection
If you are proficient with a soldering iron this is an easy fix for approx $10
http://www.insidemylaptop.com/category/4-dell-laptops/
They have some very good step by step guides for replacing power sockets.
It could also be a dying power supply which is the second most common cause.
Replacements are easy to obtain and cost between $20 to $60.
If it is the PSU either get an original replacement (EBAY is best bet) or get one of the many multi laptop PSU's available but if you get the latter please make sure it carries enough or preferably MORE amperage than you need.
The old supply will have the details of both the voltage and current on it and you need to match the voltage exactly and keep the same or better current rating eg 1000 Mw or 1A or whatever it says.
Bob
Posted on Jul 31, 2010
Where is the LCD cutoff switch located ?
Both the D620 and the D630 use the same keyboard.
The picture below shows the keyboard.
Hold down the blue Fn key at lower left, and then press F8 while holding down Fn. Press F8 multiple times until the screen returns.
If that fails, the ribbon cable connected at the main board from the screen may be loose and removing it, then reconnecting it, is the most likely solution.
ixquick proxy com
May 17, 2014 | Dell Latitude D630 Notebook
My Dell latitude D630 is not connecting to LCD projector what do I need?
Check the connection on the Projector
Toggle the video back and forth to the projector by holdig down FN key and pressing f8 key.do this like 3 time to 4 time.
hope it helps
Oct 11, 2013 | Dell Latitude D630 Laptop Computer PC...
Dell latitude D630 wont recognize projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Notebook
Wont see projector
Sep 19, 2012 | Dell Latitude D630 Laptop Computer PC...
I have Dell latitude d630, It is switching on but no display, when I switch on my laptop, its num lock light is on. capslock light works when i use caps button. Power light is on but hard drive light...
Attach an external monitor. Does the external come on? May have to use the FN key + F8 to toggle it between the LCD and the attached monitor.
When you say that the laptop LCD glows a little bit, this makes me think the back light of the LCD has gone bad. If it displays fine on the external, then it is a pretty good chance the LCD back light has failed. If you can attach an external monitor and see something on it, run the built hardware test. This is done from a powered down state. Then press the FN key + Power, this places it into the diagnostic. Follow the on screen instructions. If it comes back with an error code, write this down and compare it to this list at Dell website. http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=14B3819735D6B40EE0401E0A55177ED2
Occasionally, reseating the LCD video cable to the mother board will have a positive effect. Here is a link to the online service manual that explains how to reset it. In the diagram it is labeled #5 It is located under the keyboard.
Aug 10, 2010 | Dell Latitude D630 Notebook
My dell d630 won't show anything on the screen, it only lights up but then the next moment it will be fine and everything works fine please let me know if anyone have any idea where the problem might be
Hi. You can Run the Dell Diagnostics to determine the source of issue by pressing the Fn key and Power button at the same time.
Wait until the Dell Diagnostics appear.
If the Dell diagnostics doesn't come up, your motherboard needs replacement.
Jun 09, 2010 | Dell Latitude D630 Intel Core 2 Duo T7250...
I cant get my projector to see my dell d630 laptop ? which f buttons do i press ?
Hold down the FN button and as your doing that push the F8 key. That will force the laptop to use the output on your laptop so your video can be shown on a lcd monitor but it should also be able to be used on a projector. Make sure the settings on your projector are set properly as well.
Dec 18, 2009 | Dell Latitude XFR D630 Notebook
I have a latitude D630. The fan is not turning and no video
first look for the fn key and the f8 key
press together, if nothing
the video card sometimes comes loose on the dells, by pressing on the keyboard sometimes will push the contacts back together, if nothing install new video card on ebay
Mar 08, 2009 | Computers & Internet
Dell d630's screen is not responding..
You have NO screen?
Press and hold the blue Fn key (lower Left near Cntl) and then press the F8 key (Top row center) to switch between LCD, Both, SCART, None and repeat each time you push F8 ;-)
Next time... DO NOT Press Fn+F8 unless you KNOW this ;-)
Nov 25, 2008 | Dell Latitude D600 Notebook
Print Screen Function
On the top row, on the right hand side, second from the left, there should be a Print Screen key (Print Screen / SysRq). Just press that key once - it should give you a PrintScreen.
Jul 20, 2008 | Dell Latitude D630 Notebook
Dell Latitude D630 Notebook Logo
140 people viewed this question
Alun Cox
