Question about Garden
13.5 tecumseh surges after warmup. changed plug, air filter, and fresh gas.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 171 Answers
Sounds like a fuel mixture problem. try adjusting.
Posted on Jun 23, 2013
mowerman1857
  • 389 Answers
SOURCE: stx38 yellow deck, can't keep running. changed
Try cleaning the carburetor including the main jet
Posted on Sep 14, 2009
Testimonial: "Cleaning the carb helped."
  • 13 Answers
SOURCE: my tecumseh engine 5hp leaks gas threw the carburetor to the airf
stuck needle valve or bad float in carb.
Posted on Mar 27, 2010
  • 77 Answers
SOURCE: New Tecumseh ohh60-71216E go kart engine stalls
One of your fuel adj. on your carb may be out to much causing it to flood,check those out first.
Posted on Aug 10, 2009
  • 10865 Answers
SOURCE: Toro lawn mower wont start (super RECYCLER)1998
Hi. Get a can of starter fluid from your local auto parts store and a helper. Squirt a little into the air intake, start it and have your helper continue to squirt more fluid to keep it running until you clean the gunk from your carburator. J.
Posted on Jul 22, 2010
heatman101
  • 43501 Answers
SOURCE: Have a LT1000 starts fine
There is a kill switch under the seat that makes sure you stay in the seat if the mower is running...my bet is that the switch is malfunctioning and the vibration of the motor is causing it to short out...get a new switch, they can't be that much...
heatman101
Posted on Aug 04, 2010
Tecumseh XL 2338 E OH 160 170 170 G Manual
.030 is the plug gap. the air and fuel you can get at any mower parts store
Feb 17, 2017 | Tecumseh Garden
How do I fix a surging Tecumseh engine on my 1988 Troy-bilt rotor tiller?
Clogged fuel inlet line or fuel filter. It's not getting enough fuel to run
May 09, 2015 | Troy-Bilt Garden
I have a 8h.p.Tecumseh tvm195 it doesn't want to
Replace spark plug. Replace air filter. Fill oil. 30w. When plug is removed pull rope several times to blow out cylinder. With air filter removed spray starter fluid into air intake hole of air filter, try to start.
Ensure fresh gas only is in gas tank. Always add Stabil to gas. If no start clean carb or replace. carb.
Jul 10, 2013 | Garden
Model 917.388190
Check the air filter.
Aug 25, 2012 | Garden
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
I have spark but it will not start
Drain the gas and carburetor and refill with fresh. Clean the air filter if it is dirty. See if this helps.
Dec 02, 2011 | Tecumseh Snowblower Snow Blower Starter...
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
