Question about HP DesignJet 3000cp InkJet Printer
I have a hp3000cp printer with error printhead contact error
I have run the printer in service mode and it prints the calibration setup colours ok and printhead alignment ok but when it re- initialises it comes up with this error can anyone help? Paul
MUKHTAR
  • 2022 Answers
SOURCE: Print product alignment
just scan the alignment page and complete the process it will not promt you do again. bye
Posted on Sep 22, 2007
  • 238 Answers
SOURCE: Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Posted on Dec 16, 2007
SOURCE: HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Posted on Oct 01, 2008
  • 48 Answers
SOURCE: Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Posted on Jun 03, 2009
  • 15 Answers
SOURCE: HP L7680 print head problem
When installing the print heads out of the box you MUST shake them for 30-60 seconds, same goes for ink tanks. If you do not then the lubricant that is added to them will seperate and it will draw thinned out ink causing damage to the print heads. Also, if your system sits for more than a couple weeks (and this goes for ALL printers) then run a test page ence every 2 weeks to keep the system from drying out.
I used to work at a couple office supply stores and this was almost always the issue with bad printheads on HP, Brother and Cannon printers.
Posted on Aug 31, 2009
How can I get rid of lines on photos
Sir/Madam
Step one: Retry the print
If printing on glossy paper was paused or interrupted in the middle of the print job (for instance, if a cartridge was replaced), the resulting print may show a grainy band. In this case, retry the print and avoid interrupting the job.
Step two: Free up system resources and ensure direct communication
The PC can cause the printer to pause if it is not fast enough to keep the printer fed with data. The following steps can help alleviate this problem.
  1. Make sure that the PC meets the minimum system requirements for this printer.
  2. Restart the PC.
  3. Close out of all programs except for the program the print out will originate from.
  4. Shut down programs running in the Task Bar by right clicking on them and choosing exit. These programs will restart the next time the PC is rebooted.
  5. Ensure that the USB cable is 10 feet in length or less. Make sure the USB cable goes directly from the printer to the PC with no intervening devices in between such as a USB hub.
Step three: Check the paper or specialty printing material
  • Make sure the media is not damaged, scratched, or curled. Always store printing materials in a sealed plastic bag, especially in a humid environment, to help protect the material from damage or curl.
  • HP inks and media are designed to deliver optimum results. Other media may not perform as well.
Step four: Increase the print quality mode
If reprinting did not help and the paper or specialty printing material is not damaged, check the print quality mode:
  1. Open the Printer Properties dialog box.
  2. On the File menu in your software program, click Print .
  3. Make sure your printer is selected.
  4. Click the button that opens the Properties dialog box. Depending on your software program, this button might be called Properties , Options , Printer Setup , or Printer .
  5. Click the Features tab.
  6. In the Print Quality drop down list, choose a higher print quality (for instance, if the print quality is Fast Draft or Normal , switch to Best or Maximum DPI ).
Step five: Clean the printheads using the printer control panel
If you still see streaks or lines in your printouts, clean the printheads using the printer control panel.
NOTE:Always allow the printhead cleaning routine to complete. If the printer loses power in the middle of a cleaning, make sure to repeat the cleaning and allow the printer to complete it.
  1. Press Menu on the printer control panel. Figure 3: Menu button on the printer control panel
  1. Using the arrow keys to move through the menu options, find and select Clean printheads , and then press OK .
  2. Following the directions on the printer screen, load paper so the printer can print a test page after cleaning the printheads. Use plain paper to conserve photo paper.
  3. Press OK to begin cleaning the printheads. A Print Quality Diagnostic page prints at the end of the cleaning. Figure 4: Print Quality Diagnostic page
  1. If there are white lines across any of the color blocks on the Print Quality Diagnostic page, press Cancel to repeat the cleaning.
  2. Cleaning may be repeated a number of times. The number of cleanings (and therefore the length of the procedure and the amount of ink and paper used) will vary depending on the severity of the problem. A Print Quality Diagnostic page is printed after each cleaning. Look for white lines through the blocks after each cleaning, and if the print quality seems to be getting better (fewer white lines), continue to repeat the cleaning. Eventually, a Recommend Six-Minute Cleaningmessage will appear on the printer display. If the print quality has been improving, press OK to perform six-minute cleaning.
    • As soon as the white lines no longer appear in the color blocks, the problem should be solved. Print a normal print job to confirm that the print quality is acceptable.
    • If the print quality is still bad after the six-minute cleaning, or does not improve with repeated cleaning, or is not acceptable even though there are no white lines through the color blocks, go on to the next step.
      Step six: Align and calibrate the printheads
      If you still see streaks or lines in your printouts, align and calibrate the printheads.
      1. Align the printheads:
        1. Load plain, white, unused paper in the main tray.
        2. Press Menu on the printer control panel. Figure 5: Menu button on the printer control panel
    1. Select Calibrate Printer , and then press OK .
    2. Select Align Printheads , and then press OK .
  1. Reset the closed loop calibration:
    2. Select Calibrate printer , and then press OK .
    3. Select Reset closed loop calibration , and then press OK .
    4. The printer LCD will display Ready .
  2. Color calibrate the printer using closed loop calibration.
    1. Load HP Advanced Glossy Photo Paper in the main tray.
NOTE:Only HP Advanced Glossy Photo Paper should be used for this process. If plain paper is detected by the printer, the calibration procedure may fail or print quality may be affected.
    2. Select Calibrate Printer, and then press OK.
    3. Select Closed Loop Calibration, and then press OK.
Step seven: Clean the printheads manually
If you still see streaks or lines in your printouts, clean the printheads manually:
  1. Gather the following items to clean the nozzles on the printheads:
    • Distilled water (tap water might contain contaminants that could damage the printheads)
    • Cotton swabs or other soft, lint-free material that will not stick to the printhead
    • Sheets of paper or paper towels to rest the printheads on
  2. Open the top door of the printer.
  3. Press and hold OK until the printhead assembly moves to the left side of the printer and stops.
  4. Raise the printhead assembly cover.
  5. Remove a printhead and place it on a piece of paper with the ink nozzle plate facing up.
    Figure 6: Removing a printhead
NOTE:Do not touch the ink nozzle plate with your fingers. Touching the ink nozzle plate will result in clogs, ink failure, and bad electrical connections.
NOTE:Do not leave the printhead outside the printer for more than 30 minutes. Ink nozzles exposed to the air longer than this might dry out and cause printing problems.
  1. Lightly moisten a cotton swab with distilled water and squeeze any excess water from the swab by pressing it against a clean plastic or tile surface. Do not use your fingers to squeeze the excess water from the swab, because the oil from your fingers could contaminate the swab.
  2. Gently wipe the nozzles on the printhead with the cotton swab. Figure 7: Wiping the nozzles
  1. Wipe until no ink residue or dust appears on a clean swab.
  2. Insert the printhead in the printer.
  3. Repeat the steps above for each printhead. When all the printheads have been cleaned and reinstalled, close the top door of the printer.
    NOTE:If a message appears on the printer screen directing you to replace a printhead, click the Contact HP link on this page to contact HP support.
Step eight: Replace the printhead
If you still see streaks or lines in your printouts after performing all the steps above, one or more printheads may need to be replaced. If your printheads are still under warranty, click Contact HPon this page to arrange to replace the printheads.
I Hope Your HP Printer Problem Is Solved By Now,In case You still Having HP Printer Problem,Then I suggest You Visit Below URL Link:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00725354
Or
If You still Need assistants Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP PSC 1209 All-in-One InkJet Printer
My yellows ansd greens are switched
there are a number of possible errors here.
have the machine align its printheads
then have the machine complete colour calibration ( you will need good working printheads to complete the calibrations
when this is finished have the machine print out its config pages and demo print page ( you can find how to do this in the online user manual) this is done to Isolate the printer from the fault - if The demo page and config pages are printed correctly then the error lies external to the printer ( the software printing the document)
OR
check to see if the correct printer driver is installed (to be sure uninstall then re-install) open the driver and check to see in Preferences/colour that the settings are 'let machine decide colours'
or set to adobe pdf. print out the test page from the driver and pay close attention to the windows logo at the top of the page- it should match that on the windows start screen
if you can see that the green yellows are still out of calibration then you may need to change the printheads ( CYAN/Yellow) as the error may lie internal to the printhead.
at the end of the day the fault lies most likely with the software setup or the printheads.
Jan 18, 2014 | HP Officejet Pro L7480 All-in-One...
HP Calibration Error
    For HP Officejet 6600 / 6700 printer models which suffer a calibration error, more than likely either the PRINTHEAD has connectivity issues (i.e. remove, clean all contact points, and reinstall), compatible/clone ink cartridge chips are causing the issue, the PRINTHEAD is approaching end of life, or not all ink nozzles are firing and therefore the printer is unable to calibration. Perform the following diagnostic checks to help make a determination:
    Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen 6600/6700/8600/8700 printer models only):
      1.Press 'Return' button (lower left side) four (4) times until 'Support' menu is displayed.
      2.At 'Support' Menu, using the arrow key, navigate to the 'Service Menu', press Ok.
      3.Use arrow keys to advance to the 'Special Reports' Menu. Select OK.
      4.Use arrow keys to advance to the 'print mech button tap' menu. Select Ok.
      5.'code = 0' will be displayed. Use arrows keys to change value to '41' (i.e. press and hold right arrow key).
      6.When 'Code = 41', select 'OK'. The diagnostic test pattern will print.
      7.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced. Re-seat PRINTHEAD and/or clean rear electrical contacts and repeat 'Tap 41' test to verify connectivity is not the issue.
      Nozzle test (use to determine if all ink cartridge nozzles/printhead is firing all colors properly)
      Press return arrow 4 times
      2.Press support menu
      3.Press right arrow 5 times to print diagnostic menu and press ok
      4.At nozzle test press ok
      Self test/printer status (use to print internal printer settings)
      3.Press right hand arrow 7 times to reports menu and press ok
      4.At self test report press ok
      Extended self test (use to evaluate color performance and obtain total page count)
      4.Press right hand arrow 1 time to extended self-test and press ok
      Print Quality Diagnostic Page (use to determine if printing alignment is correct)
      4.Press right hand arrow 2 times to Print Quality diagnostic report and press ok
      Print head recovery (runs 'intensive' printhead service cleaning routines, i.e. for a clogged printhead)
        1.Press home key twice
        2.Then return key
        3.Then home key twice
        4.Then return key
        5.Then home key twice...............this will gain access to the Engineering Menu
        6.Press the 'service menu'
        7.Press right arrow 4 times to 'service test' and press ok
        8.Press right arrow:
        a.16 times to 'print head rec level 1' (basic recovery)
        b.17 times to 'print head rec level 2' (medium recovery)
        c.18 times to 'print head rec level 3' (thorough recovery)....suggested for severe streaking
        9.Press 'ok' to activate either of the 3 selections above.
        Semi full reset (can be used to help address intermittent or incorrect printer behavior issues)
          1.Press return arrow 4 times
          3.Press right hand arrow 2 times to Resets menu and press ok
          4.Press right hand arrow 2 times to semi full reset and press ok (Note: this will return printer to factory default condition; regional setup will be required following this action)
          For more information on inkjet printer recovery tips, or solutions for a different printer model, please visit http://www.inkjet411.com
          -Thank you
Nov 22, 2013 | HP OfficeJet Office Equipment & Supplies
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
I860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Dec 29, 2007 | Canon i860 InkJet Photo Printer
HP DesignJet 3000cp InkJet Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
