Question about King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P
Ford 951 special bush hog, type gear oil - King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P
2 Suggested Answers
  • 474 Answers
SOURCE: what should you use in the gear box for a bush hog
90 wt gear oil
Posted on Sep 27, 2009
What gear oil do you put in arron cobra 100cc
You can use 10-40w motor oil. You don't have to waste your money on special gear oil made just for motorcycles. There isn't anything special about those so called gear-oil type oils.
Oct 22, 2016 | ATVs
Ford 2000 tractor stalled bush hogging (Too slow near the fence line, no engine prob). PTO was engaged, was in 2nd/high. Cant get it out of gear to restart.Cant lift the bush hog up--cant do anything.
Have someone help you rock the tractor back and forth and see if it lets go ,if not jack up rear wheels and rock them back and forth.
Aug 31, 2016 | Ford Garden
Why distributer drive gear lays done
check the drive system for the distributor
ford employ a shaft that drives the oil pump and if the oil pump is under undue stress, it strips the gear or breaks a shear pin
all the gear is driving is a distributor shaft and in the first instance could be a seized bush for the shaft but with replacements failing I would be looking further afield , like an oil pump
Apr 04, 2016 | 1994 Ford Taurus
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
What causes balance shaft bushes to burn
Loss Of Oil Pressure is usually the Cause.Looks like its time for a new Engine, But You're Problem was Probably caused By the Wrong oil and Or No oil Pressure.I've had People tell Me they Used a Heaver Oil for summer time and A lighter Weight oil for winter, This Used to be an ok Practice in the Past, with Solid Steel Blocks But was NEVER Recommended Ever, Since the Change in oil weights eventually Breaks down the he Bearings from the differences in Viscosity in oils,But With the Newer and lighter Aluminum Blocks, Every thing Affects the Performance of the integral Parts IE:Bushings, Bearings, Seats ,Lock tabs, Shear pins/Keys .
So Now You need a new Engine Sorry
May 04, 2014 | Ford Taurus Cars & Trucks
My oil pressure dropped on my 8N while bush hogging. Then it jumped up and down.
oil pressure vavle in front of the motor is bad or the spring is weak.
Aug 30, 2010 | Ford 8N Tractor
Is the gear box on an old Woods Bush Hog packed in grease or a heavy weight gear oil and what type is best. How do you prevent leaking
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Aug 19, 2010 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Hi - recently bought a new KingKutter 4ft bush
go to kingkutter.com and download the manual.
hatter1
May 15, 2009 | King Kutter Pull Type Rotary Kutter 72in....
Shifting gears very stiff.
I am afraid I bare bad news... the transmission is suffering from swollen selector fork bushings. ATF fluid swells the bushings up, it used to be what was used to lubricate the transmission. however ford has long ago changed the specs to what is called Ford Honey manual trans oil its has a brown honey color or royal purple synchomax. they only fix for this is to replace the selector forks and inly use ford honey manual trans oil. there is a TSB issued for the fluid.
Jun 17, 2008 | 1999 Mercury Cougar
King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Logo
214 people viewed this question
Top King Kutter Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a King Kutter Tool and Hardware - Other Expert? Answer questions, earn points and help others
