Broken programme dial knob on Tricity Bendix Wdr1040w washing machine
  • david fraser Apr 18, 2013
    i posted this to help others as i have managed to fix it. solution follows...
    The programme selector dial on my 10 year old washing machine broke so it spins freely and therefore the machine cannot be used at all. I have now resolved this - but wanted to post this so others can follow the fix, as when I spoke to Tricity Bendix/Electrolux, their only solution was to replace the whole machine for the sake of a snapped bit of plastic that I have now replaced for gbp7. So - to fix 1) Unplug the machine 2) Remove the top lid by removing 2 screws at the back of the lid 3) Remove the centre of the programme selector dial by reaching down behind the front panel with a screwdriver and release the two plastic tabs holding the centre of the dial into the outer ring. Pull out. 4) Remove the outer ring of the programme dial by undoing the metal nut on the front, then reaching down and release the 3 plastic tabs that hold it onto the front panel piece. 5) This outer dial was what was broken - it should have a ring of teeth and tabs in the centre on the back that fit into the yellow Cam wheel. 6) Purchase Part number 1248201004 as replacement. This is actually for machine CAW1010, but is physically the same part. Note the WDR1040W part number for the obsolete dial is 1321499301, but the number printed on both is 12477630 - this is the moulding number, not the part number 7) (While waiting for delivery, mark on the yellow cam wheel the programme positions you need, and turn it with a screwdriver to still use the machine) 8) The new part has the numbers printed in the wrong place - hold the old and new together and mark the numbers by hand ! 9) Refix the dial (it only goes on way round - align the larger tab in the centre ring with the gap in the yellow cam. REplace the nut, click the centre cap back in place et voila. Saved having to buy a new machine.
4 Suggested Answers
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: what is the quickest wash cycle for the tricity
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Hope this was helpful.
Good Luck
Posted on May 06, 2010
Daniel S
  • 4323 Answers
SOURCE: tricity bendix aw1002w front loading
Hi
The issue is either with bad door lock-switch assembly or the control board that is bad and should be replaced. You can take the control apart and check the wires & also if any button is stuck you can unstick that and if the issue returns replace the control board. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 23, 2011
Setting fast colours at 3 keeps jumping to 6
Ensure you are programming correctly check your instruction book. Some programmes will ignore your commands if they are not compatible.
Jul 24, 2014 | Tricity Bendix WDR1040W Front Load Washer...
Need a timer and where do i get it from for a bendix front loader l105rx
Look up SERVALL for your closest location. Or from an appliance parts distributor. All you need is the model# and what it is.
Aug 22, 2010 | Tricity Bendix WDR1040W Front Load Washer...
What is the quickest wash cycle for the tricity bendix wdr1040w front loader
Good Luck
May 04, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Not spinning at all! Does the entire cycle without moving! Thanks
Either the belt has come off, or broken, or the motor is not working.
You would need to remove the motor to check it properly.
Please tate my solution.
Thanks.
Sep 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Apr 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
DIal is misaligned!
It could be a faulty water heater stat ,or the hot and cold fill pipes are the wrong way round. close Ireland bye bye
Sep 01, 2006 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
