Question about Wahl Health & Beauty
152736 100-130v/50-60Hz Switching Adapter 6000
Need to buy replacement Adapter 6000
Voltage on ss-6000. Lost my ac adaptor, what kind do I need to buy?
This AC Adapter is available on Amazon @ http://amzn.com/B00ACNGMO8
Hope you find this information to be helpful.
Oct 21, 2011 | Homedics Sound Spa Platinum SS-6000 Clock...
Wont turn on keeps switching off
Have you used AC adapter or just battery in the laptop?
Remove battery and use AC adapter to turn it on to see it helps? If not, then laptop has a problem (circuit board)
Aug 16, 2011 | Dell Inspiron 6000 Notebook
My Dell Insipirion 6000 is not switching on
Check for a bad battery or it is a bad charer, chek and see if the charger is putting out the right enoth voltage, if not you can by a charger at best buy,
Jun 02, 2011 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 is not working. At first, I thought the problem was the charger/AC adapter. After buying a new one, the computer still won't turn on. When the computer was working though, it was...
Hi
My acer laptop told me to replace my battery so i got it from ebay for a good price
but you should still be able to use your computer without the battery while plugged in
Jan 30, 2011 | Dell Inspiron 6000 Notebook
Inspiron 6000-flashing battery light
Since you said the battery is not charging, why don't you remove the battery and charge directly to see if your laptop adapter will charge your laptop. Because i for see your laptop adapter been bad that is why it is not charging your laptop.
If it did not, it means your laptop adapter is bad and will need to be replace in order to charge your laptop.
Just change the adapter as advice and your laptop will charge.
Take care.
Apr 19, 2010 | Dell Inspiron 6000 Notebook
Second time this has happened, Apricorn ez bus dts power supply
You can use a universal Adapter.
All you need to do is to match the correct voltage and the correct Ampere.
Lets say for example the input of your adapter is : 100-240v, 50,60hz . and 0.5 A
the output is : 12vor 5v 2A
So check this that correspond to the one you already have.
But one thing :: don't use one that is of a higher voltage capacity.
It will burst out forever the disk........
If you need any further help please let me know.
Regards
Uttam
Jan 29, 2010 | Apricorn EZ Bus DTS (EZ-BUS-DTS-500e) 500...
When adapter plugged in computer starts then goes
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | Dell Inspiron 6000 Notebook
I need to buy a zx-6000 wireless headset ac adapter or discover details about the recharger (voltage, current, ...)
any ac adapter will work, search on for the specs of the head set pertaining to the power requirments and go buy one. mmm i just looked around and it seems its a little hard to find so here it is,
input : 100 - 240 v
50 - 60 hz
js p 0.25a
Oct 26, 2009 | Microsoft LifeChat ZX-6000 Wireless...
My inspiron 6000's power flickers on and off intermittently, switching between A/C & battery power. I've replaced the power cord. Any other ideas?
Try removing batt and use ac adapter alone. Check if laptop works fine also check if LED flickers still.
Try removing ac adapter and use battery alone and check if batt flickers as well.
If flickering only happens when both are connected or vice versa try this first. Update the BIOS for your laptop. Download the BIOS update from http;//support.dell.com
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Health & Beauty Logo
210 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
