Question about Car Audio & Video
Which one is live which one is negative - Car Audio & Video
    New Friend:
Thick one is always live green it lookedthe one nxt is neg,ull have 4 speakers wire so rap the one that's left round positive for auxiliary power so it keeps memory
Posted on Jun 30, 2013
  • Andrew Brown Jun 30, 2013
    Red negative, green live, blue aux, and the 4 next are speaker wires. I always try cassette with battery charge 12 volt.
Signal lights will blink but I have to hold the button to keep them on
hi,that shows the button is not making connection ,check wires to button and to make sure,,get a brown live to switch and to battery, and negative blue too and negative and live to switch and earth to body of car,,basically its a black wire to switch,along with red wire to switch or blue.then attach to battery of car... but put an earth wire to body of car , or change switch could be loose connection in side ....hp that helps,-)
Apr 24, 2015 | Vehicle Parts & Accessories
How do i hook up a pioneer deh 1700 to my car wire colors do not match
You are going to need a multimeter to find a permanent live wire the switched live and the negative for starters if you are removing an older stereo it might be easier as the switched live is normally to the red wire the yellow is permanent live and black earth from your pioneer you will have a blue that is sealed off that is the electric ariel or signal to an amp the rest of the wires ar plus and negative speaker wires.
Sep 16, 2014 | Pioneer Car Audio & Video
Fuses are constantly blown in Navion 2013 24V --lights in living quarters have gone ou (more than once), keyless for living quarters would not work and slideout would not extend sideout would not exte
Are you sure that the system is 24v? Most RV's these days are 12v and may have two batteries that are wired parallel. If they have been rewired in series you have increased the voltage to 24v and that is why the bulbs are not lasting and everything else is failing. To wire the batteries in parallel, negative will be wired to negative and on to the negative or ground lead. The positive will be wired to the positive and on to the positive lead. If the battery is wired from ground to negative and from positive of same battery to negative of the next battery and positive of second battery to positive of the system then it is wired in series and that would be wrong.
Apr 20, 2014 | Itasca RVs
Online chat
It requires 2 power connections and a negative to work, have you tested your power cables to see if they are live. The one live can be connected to both the yellow and red cable. Make sure black is connected for negative and it should work then. I strongly suggest getting a phase tester to see if there is alive first though. You could have blown fuses and wont know till you test
Oct 15, 2013 | Car Audio & Video
What size battery for cub cadet 2006 cub cadet
Most machines will have a negative earth, this is normally a black wire , follow the wire , it will be screwed down to eart against the chassis, the live wire will be red, follow this wire and it will go to the start solinoid, there may also be a low tention wire from the live terminal this will have a fuse somewhere in it,
Mar 04, 2012 | Northern Tool Lawn Mower Battery 12 Volt,...
What is the blue wire for:; Is it positive or negative please what is the brown wire for: Is it positive or negative and is the yellow and green the...
Blue = Neutral, Brown = Live and you are correct Yellow & Green = Earth
The live wire (brown) must be connected to the fuse if there is one.
You could say that the blue wire is negative (or zero) and the brown wire is positive as this is the one the high current passes through. The blue wire completes the circuit, which is needed for current to flow.
Hope this helps!
Oct 13, 2010 | Riccar Sewing Machines
I am trying to hook up an antec ar300 power supply to the outlet that lets it be plugged into the wall. there are three wires ... green white and black... i can not figure out which one is positive which...
The green is ground. There is no "positive" and "negative" because the current in the outlet is alternating (AC). They are called "Live" and "Neutral". The Neutral i safe to touch, the Live is deadly. There is no difference how to connect them - in both ways the power supply will work.
Aug 07, 2010 | Antec AR300 300-Watt Power Supply
NEED STEREO WIRE COLORS FOR 1988 BMW 735I
red = constant live 12v
brown = negative ground
violet = ignition live 12v
white = electric antenna (rear screen)
the speakers will be twisted pairs, i can not remember which is left and right but the grey stipe and brown strip are negative the others are positive.
If in doubt get a pro to install for you as you could cause damage if you connect wrongly.
Nov 25, 2009 | Car Audio & Video
Ionizer
IONIZERS to not PURIFY indoor air. IONS are either NEGATIVE or POSITIVE. In this case, the NEGATIVE IONS are the 'GOOD GUYS!"
An ionizer will usually put some negative ions into the air while trapping, just like positive/negative magnets would do- SOME of your airborne live contaminates onto a metal plate inside the ionizer. When you pull out the plate with this smorgasborg of contaminates to wipe it, some of them can go airborne again, plus you have a dirty cloth ripe with contaminates on which you should then throw away. You haven't PURIFIED your air-you've just added some negative ions to your air, which will make your air feel light and lively- but still not PURIFIED.
Our SUN AIRE purifiers not only PURIFY indoor air SAFELY and EFFECTIVELY like SUNLIGHT, but one of the side-benefits is that we replenish your NEGATIVE ION balance in your air because of our SUNLIGHT process of purifying your air.
We DO NOT LIVE in our ductwork, therefore, our SUN AIRE purifiers purify your air in your living spaces FIRST and then the allotropic oxygen can be sucked through your ductwork.
POINT-OF-CONTACT is the key to our SUN AIRE purifiers effectiveness. We recommend you place your SUN AIRE purifier as FAR AWAY from your cold air return as possible because we want you to use the allotropic oxygen FIRST, before it's sucked through your ductwork.
Thanks for your question. Please let us know if we may assist you.
www.betterair.com
Oct 04, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Car Audio & Video Logo
275 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
