Question about iKey Audio M3 Portable Digital Recorder with Color Display & SD Card
Service manual for IKey M3
SD Card slot no longer working. USB works fine
Usb device not recognised?
did it load up with or without a cd prog.
go to programs and remove the program.
Restart computer then reinstall as from new. fingers crossed.
Jun 28, 2014 | iKey ICONNEX Portable USB Sound Card,...
3.0 doesn't work
motherboard has to have usb 3 too
Apr 13, 2014 | Rosewill RDCR-11004 5.25" Internal Card...
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
I want to transfer music from my computer to my cell phone...other laptops have a sd memory card slot...where is the one for the compaq cq60-466dx
Your laptop may not have a sd memeory card slot, if it has it should be either the front or either side, if none there, you can link your mobile phone to your laptop using a compatable usb. Should have had one provided when brought your phone.
Mar 05, 2011 | Compaq Computers & Internet
Manual says virtually nothing about adding memory
If it's a newer laptop, generally the maximum is 4 Gigs. If it have an SD card slot, it will take SD cards. Most other cards can be made to work with an SD card slot if you buy an adapter. If it doesn't have a card slot, you can buy a multi-card reader for USB for under $20.
Feb 27, 2009 | Toshiba Satellite A105 Notebook
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Dec 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Sd card
have you try to insert it to another computer?
Feb 14, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
XP won't boot with NEC SD-V2-5U USB card installed
Have you tried moving the card to a different slot? The motherboard BIOS and/or the operating system may be trying to assign an interrupt that cannot be shared--especially if you have the card installed in the slot next to the video card (or shared with the onboard video).
Nov 06, 2007 | NEC SD-V2-5U (SDV25U) Serial Adapter
iKey Audio M3 Portable Digital Recorder with Color Display & SD Card Logo
101 people viewed this question
Top iKey Computers & Internet Experts
David Payne
David Payne
Are you an iKey Computer and Internet Expert? Answer questions, earn points and help others
