Question about Philips 50PFP5332D 50 in. Plasma Television
Changed a 3300mf 100 volt capacitor in power supply was blown when i plug tv in red light standby light comes on then i hold in power button blue light on light comes on it doesnt flash but no picture or sound at all
    Top Expert:
  • Philips Master
  • 43,012 Answers
Apparently not all of the power supply problems have been fixed
Posted on Apr 18, 2013
  • 90 Answers
SOURCE: philips lcd 37pf9431d/37
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
Posted on Feb 23, 2009
dsacco86
  • 1077 Answers
SOURCE: 32" polaroid LCD TV No Picture
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
The best thing to do is find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
Just better this way so it doesn't waste more of your time. :)
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
maatmartin7
  • 1216 Answers
SOURCE: magnavox 42mf521d/37 sound but no picture
The solution is the same I used for srjohnnichol, June 4, 2009. I promise you, this will correct your problem. Stop waiting an getter done!
Posted on Aug 01, 2009
SOURCE: No Picture and Red Blinking Light
I had this problem on a 42" Philips Ambilight. After reading in another forum, opened up the back, and found 2 leaking capacitors on the center circuit board (main power supply pc board) toward the bottom. Tops of the capacitors were bludged out (10v 3300uF) and leaking electrolytes. Unsoldered the old ones myself, went to Radio Shack. They were out, so order 12 on ebay for $6.63 including shipping. Resoldered and works fine. Can't do it yourself? Take the board out (just unhook the cables & unscrew it ), and take it to a computer shop or tv repair or someone who knows how to solder, and have them change them. Piece of cake!
Posted on Oct 01, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
How do I fix my LG 42PG25 plasma TV? The model number is 42PG60UA. What should I try next see details below?
It is 19 years old, and I would say beyond economical repair. You will be chasing blown components that were damaged when the power surge or brownout occurred. It is only a 42" set and it is plasma. Technology has moved on to 4K Ultra HD, LED and smart hubs. Treat yourself, it's Christmas :>)
Dec 19, 2017 | LG Televison & Video
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
SAMSUNG TV UN65JU6700F RED LIGHT BLINKS 6 TIMES . TV DOES NOT COME ON AT ALL
My Samsung 50 inch had the same problem. Searched the web and it was the only capacitor in the power board that needed change, voltage was 382 volts. Replaced the old 100 uf 450 volts capacitors with two capacitors 150 uf 400 volts and 220 uf 400 volts in parallel and measured the high voltage at 390 and the TV was back to normal. (Make sure the capacitors from an old TV and computer power supply is rated for at least 400 volts.
Oct 27, 2017 | Samsung Televison & Video
Hi my TV bush 50/211f not turning on still standby red light, I m change supply board still problem today I am changing main board and turn on. light change to Blue 10 sek back red and again
try this Press and hold the on/ off button Whilst holding unplug the plug from the wall Continue holding for 30 seconds Plug in the plug whilst continuing to hold the on/ off button Continue to hold for a further 30 seconds And the screen should come back on, good luck
shaun
Mar 11, 2017 | Bush Televison & Video
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
42" plasma worked fine this
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Sep 15, 2011 | LG 42PC3D 42 in. Plasma Television
Philips 50PFP5332D 50 in. Plasma Television Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
