Question about Canon Printers Pixma PRO-100 Photo Inkjet Printer Black 6228B002
Green colour cast with canon pixma pro 100
When printing black and white images I'm getting a green colour cast
frcs68
  • 1605 Answers
SOURCE: canon Pixma 4500 when printing
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Posted on Nov 12, 2008
Randyincv
  • 17 Answers
SOURCE: bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
Posted on May 24, 2009
benwabnick
  • 2404 Answers
SOURCE: Will the canon pixma mp240 continue to print
you need to have both cartridges somewhat full to run, there is a initialization routine that the printer goes thru and if you don't have good cartridges with ink it won't let you print.
Posted on Aug 16, 2009
SOURCE: Canon Pixma Mp145 to print only black.
i have a canon mp145 printer
i just know wan to how access to load byprint
Posted on Feb 07, 2010
  • 111 Answers
SOURCE: Canon Pixma 3600 I want black
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Posted on Jun 06, 2011
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
example:
Jun 06, 2011 | Canon Office Equipment & Supplies
How do I print a negative black & white photo...it keeps printing a yellow tone image?
hi...while you give the printing command go to option and select black and white option. u can get black and white.
If u get yellow tone image means that the catridge of black might hav finshed please check the catridge and replace it.
Jul 05, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Black & white to colour for printing
it might be in the printer properties that shows up in the popup config when you print HP has it canon should it is a good sensative printer
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Using Canon iP4600, I'm trying to print a black-and-white photo with a black background and a half-tone image in the front, but I keep getting purplish and black stripes instead of an all black background....
Hi there
Sometimes, printers use colors from the other cartridges in order to form a deep black colour. It does seem that not enough pure black ink is getting onto the paper.
Can you check that there is enough black ink remaining? If so, go to the print options of the program from which you are trying to printer the image, and set the colour output to black or greyscale only. This may be within an option called Printer Preferences from the Print dialogue window of the program from which you are printing from.
Then, print an image as a test and see if it comes out in black only this time.
I look forward to your reply.
Regards
Jul 25, 2009 | Office Equipment & Supplies
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Printers Pixma PRO-100 Photo Inkjet Printer Black 6228B002 Logo
139 people viewed this question
old marine
old marine
