Question about Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool calypso washer vibrates at the beginning of the spin cycle. what causes that?
Alarm which we do not have before. normal cycle. also on a rinse cycle. ocasionally loud banging noise.
You didn't mention if the machine was giving any error codes. Do the following steps to get any stored error codes and post them back to me.
Select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
Jan 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso - replaced pump/motor, but still get incomplete spin cycle with 'ob' and 'sl' errors. Never gets up any speed during spin cycle. What else might this be?
So here's my solution... Remove the new pump/motor combo. Go to "Appliance Center" and pick out a nice new Maytag and have it delivered the next day. Have them haul the POS Calypso away and sell the new pump. Let me know it you need a new pump....
May 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso GVW9959K washer with OB code
This is a common problem with the Calypso washers. The problem that you are having is related to the pump. There is something in the pump that is causing the error code to occur. Since the pump isn't working right all of the water isn't draining out thus causing it to be out of balance. If you can get down to the pump and check it out chances are you will find something in it. It might just be some fabric or string from clothing caught around the pump motor. Just make sure you clamp off the hoses or you will flood your laundry room. Once you clear out the pump unplug the washer and wait a few minutes before plugging it back in. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso won't finish spin cycle
Error is Insufficient cycle!
first try to unplug the appliance for 5 minutes and then restart it and see if the system reset!
if not you need hands on service. Not every situation is easy.
Please let me know what happened?
Plese rate me at our site too, before you sign off!
Thank You for using our service!
Jul 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool
I would say to worry about it , if its flooding your house , need to open washer front panel ,start a new wash cycle and take a look to see where the water is leaking from , sounds like a broken hose under the tub that connects to the DRAIN MOTOR PUMP , AND BETTER have it fix right away cause if its getting to the main motor it could damage it , hope it helps AJ
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Mar 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
