Question about Apple iMac Computers & Internet
Can not insert disk into imac
Unable to insert disk
  • Wayne MacNeil Apr 20, 2013
    Solution: shut down Mac, unplug power for 60 sec., plug power back in wait 30 sec. then turn Mac on. The disk drive will recycle and should accept disks. This worked and problem solved.
  • 331 Answers
Assuming of course the iMac is otherwise running and functioning normally, this would indicate that the drive has gone bad. Usually, when you first turn on the computer, you'll hear the drive make a sound. If this is not happening, either there is a disk stuck in it or the drive is defunct. visit this page for some tips on ejecting a stuck disk. If that does not work, you will need to replace the drive.
Posted on Apr 26, 2013
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 30 Answers
When you insert a disk, you can easily feel that an already stucked disk will block your way. If that happens, that means you need to remove the disk otherwise it really depends what kind of disk you are inserting. Some drives will throw out incompatible disks. If that is not the case the drive may be defective.
Good luck.
Tech from http://www.computerstar.ca/Macbook_repair_toronto.html
Posted on Apr 30, 2013
How to reboot a colored apple imac computer
A normal restart only requires you to press the re-start button on the back of the CPU or on the front. You should hear the chime, the screen will come up and you will be taken to the Mac start-up screen (different OS will have different looking screens).
If the Imac has shut down suddenly or prematurely, you might not hear the chime but will see a grey screen with a status bar. Eventually you will see the normal Mac screen and your icons will slowly reappear.
If you do not get any start-up screen or any chime, unplug the unit, remove all peripherals ( such as USB cables etc) and leave it sit overnight. I have restored "dead" Macs by that simple technique.
If you see a screen but the Imac still won't boot, insert the restore disc, hold down the "C" key and restart from the disk. Or use disk warrior and start the same way. Disk Warrior will diagnose and repair problems with your OS.
If none of these strategies work, you may have internal component problems with your Imac that will require more expert repairs.
Oct 12, 2014 | Computers & Internet
Apple
good idea
first run disk utilities, then defrag disk, then connect ssd to computer via usb external drive, then clone disk or install disk into machine and then insert system disk and boot from system disk and hold down c key.
Mar 21, 2014 | Apple 24" iMac Desktop
Imac will not load disk
Hi Wayne,
Put in an original install disk that came with that Mac and hold option key while booting and select the disk with arrow keys and press enter
Regards,
Sean
Apr 18, 2013 | Apple iMac Computers & Internet
Why won't disk insert into iMac
Probably not configured correctly. Have you tried this same disk in other Macs?
Oct 08, 2012 | Apple iMac Z0GF0005F Desktop
I HAVE AN IMAC 20".
You also could try
Opening up the terminal application found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Tilt your imac so that the DVD drive is pointing downwards and press the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the imac switched off insert the piece of plastic with the tape facing down in relation to the screen. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Aug 14, 2011 | Apple iMac Z0CY Desktop
My iMac g4 1ghz wont boot
First hold down the right hand shift key down when you start, this does some housekeeping, The next step is if you have an install disk or tiger disk then start up from it by holding the "C" key down when starting and inserting the dvd, if this loads then go through the install menu, dont worry you do not need to actualy install just select language and then you get to a screen where you can select utilities from the menu bar, then select disk utility and repair permissions, after that do a repair disk then quit disk utility and change the startup disk back to the hard drive and restart, if for some reason you cannot repair the disk, this refers to the catalogs it uses to keep track , not the data itaelf, in that case you need a 3rd party utility like Disk warrior.
Feb 24, 2010 | Apple iMac G4 Desktop
20" iMac Boot
Ar this is a regular problem i get when people try to install Windows XP or Linux on Boot camp e.t.c.
What's happened is Linux has Tampered with the boot up files and now it won't be able to boot into Linux or Leopard.
What you need to do is insert you Leopard Install disk that came with you iMac Into the Disk Drive, the disk/disks are grey and may be two CDs or 1 DVD.
Restart the iMac and the moment you hear the chimes go off when it boots up, Hold down C on the keyboard. The boot disk for leopard will then boot up,
From here follow the instructions and if your lucky you may be able to upgrade, if not, go through the system utility and repair disk permissions e.t.c.
If nothing works, You will have to do a clean install,
But you may be able to recover a thew images and mp3 files with a great bit of software i like to use, http://www.prosofteng.com/products/data_rescue.php
You do have to pay for it, and you will need to install it on macbook e.t.c. if you have one in order for it to work If your confused there is a number of guides out there on that website or on google
Hope i have been of any help
Regards
Jul 28, 2009 | Apple iMac G5 Desktop
Screen goes white, flashing a folder with a question mark
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk.
Insert the disk into the computer and it will boot from that and take you through the install procedure.
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
IMac keyboard volume control keys
Do the volume keys still work when you are booted in to OS X?
Also, try reinstalling the Bootcamp drivers that will appear when you insert an OS X disk when it's booted in to Windows.
Mar 16, 2009 | Apple iMac G4 20" Mac Desktop
Can't get it to work on my new iMac
You may have to go to Canon's website and download the Mac package for it. Some, but not all, installation disks contain software for PCs and Macs but either yours does not or the disk has become unreadable - a problem I have found many times.
Nov 23, 2008 | Canon CanoScan N1220U Flatbed Scanner
Computers & Internet Logo
97 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
