Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
N80 suddenly quit working
Nailer worked great; however, suddenly it quit and all it would do is leak air and make a "put-put-put" like noise. Any suggestions?
There is a nail stuck inthe grove where the nail comes out. There are 4 allen bolts on the front of the nailer.remove them and you can remove the bent nail. Put it back together and your ready to go.
Posted on Mar 12, 2009
I have a Dewalt 15 gauge angle nailer...never used it till recently. Worked great about 2 hours ,nailing up fence pickets. Now it has a small air hiss but will not fire off nailstopped suddenly!
reading the user manual reveals that it requires oil before using and regular oiling during use
that is simply attained by disconnecting the air line and putting a few drops of machine oil in the connection and reconnecting the air back up
that oil then lubricates the seals and piston of the machine
do that and it most likely will work again
Sep 09, 2017 | Dewalt Tools & Hardware - Others
D51275 dewalt nailer quit working
O ring or stuck pin valve. Id check here for more info DEWALT com
Aug 15, 2015 | Dewalt Nailer. 1 in. - 2-1/2 in. 16 Gauge...
Nailer drives nails too deep
n80 coil nailer is a very powerful nailer used for hard wood. If the driver is setting nails too deep, adjust safety foot to the lowest level. Install safety foot no-mar boot to lift the gun even higher. If still too deep, most likely the lower bumper inside the gun is worn-out or cracked. Easy test. Remove nails and connect air supply. With trigger depressed, push and hold the gun against work (I use an old rubber hose tightly coiled up). This will fire the gun but keep the driver down allowing you to examine the tip of the driver. The driver should extend out past the nose less than quarter inch. If the driver is extending too far, most likely bumper is worn out. If a large quantity of air is leaking out the nose of gun during the test, indication that lower bumper is cracked. Good luck.
Apr 06, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
Feb 10, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I Have a N80 Coil Nailer. It was given to me without the manual. I down loaded a manual, however it is not clear how to set the nail depth. Can you advise?
Bostitch nailers used three methods to adjust how deep the nail will set. On stick nailer, there are one or two screws on the lower contact arm allows you to shift up or down. On coil nailers and others , there is thumb screw on side or under the trigger. Finally on some coil nailers, there was a series of spacers that snapped onto nose of the gun. Good luck
Nov 21, 2012 | Stanley Bostitch N80s Nailer -rebuild...
Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
May 23, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Bostich N80 Framing nailer
Sorry about the delayed response. This unit needs to have the O-rings replaced. The return of the firing pin is not happening correctly. This means that the pressure release holes are still engaged. When the pin pushes out the nail, the return should cause the holes to get covered. If there is an air leak, the return will not complete resulting in an even larger air leak which is what you are now seeing. This is a relatively simple repair for any shop that handles these and would be considered a standard maintenance effort. These are decent tools and with proper maintenance will last for years. Mine is over 22years old and going string.
Jan 26, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
400 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
